XJS DIY Lesson 1
Old Nov 1, 2013 | 09:01 PM
YycXJS's Avatar
Default XJS DIY Lesson 1
Just because parts look identical doesn't mean that they are.
So I picked up my XJS because I always wanted on and I also wanted to do as much of the necessary work as I could myself (I have limited experience at best). I decided the best place to start would be to replace the map light switches because one of the wasn't working. I thought that this would be an easy "confidence boosting" project.
I found an identical looking switch on the web; purchased it and eagerly awaited it's arrival. Today it arrived and I eagerly removed the old. Imagine my surprise when I realized that although the switches appeared identical, the connectors were different. So much for confidence.
I have attached photos of the 2 connectors. Is there an adapter I can use between them or will my first project include rewiring the harness?
Suggestions?
Old Nov 2, 2013 | 02:37 AM
Greg in France's Avatar
There will not be an adaptor, or most likely room for oner. i think it best to either splice the wires to the correct connector or send a pic of the switch and connector type you need to Grublogger in the UK (who will surely have one) for the correct switch, if you cannot find one in a USA scrapyard.
Old Nov 2, 2013 | 10:38 AM
YycXJS's Avatar
Thanks. I think I'll likely splice the wires. Am I correct in my assumption that as long as I match the colors it will work?
Old Nov 2, 2013 | 10:49 AM
That would be my GUESS..but thats all it would be.
Here are some electrical diagrams that may help...
Jaguar electrical reference
Chances are that someone with more knowledge than I will be along to help
Good luck
Old Nov 2, 2013 | 11:25 AM
Doug's Avatar
Maybe I've missed something, but.....
Why not return the *incorrect* switch and purchase the *correct* switch?
Old Nov 2, 2013 | 03:59 PM
YycXJS's Avatar
Sale is final.
CXJ
Nov 28, 2015 11:41 PM
1964Daimler
Oct 3, 2015 12:18 PM
alextoevs
Sep 20, 2015 05:21 PM
Foosh
Sep 19, 2015 07:55 PM
XJsc-guy
Sep 2, 2015 11:43 AM
