XJS V12 fuel injector clamping plate threaded rod/stud issues
Old Jul 29, 2024 | 03:09 PM
Rusty British Cars's Avatar
Default XJS V12 fuel injector clamping plate threaded rod/stud issues
Hello all,
I've been working on getting my 83 HE up and running, making progress on the fuel system. The fuel injectors are all clamped in with those little plates held down by 2 nuts on these little threaded studs (different threads on each side of course). A few of them came out because the nut was pretty well rusted onto the stud, despite my best efforts with penetrating oil. I have been able to free a couple of the nuts from the studs/rods but some are still quite stuck, and I fear I'll destroy them in the process of freeing the nuts.
Anyone know of a replacement part for the threaded rod? I have looked all over and I don't see it on any of the usual suspects.
Any leads would be greatly appreciated.
Old Jul 29, 2024 | 03:57 PM
BenKenobi's Avatar
I bought a full set from this fella Donald Miles - you will need to find TWR on facebook because nothing I do will allow me to link here.
How happy he will be to do only studs I don't know ( I bought the works - injectors / plates / studs etc etc ) - no harm in asking I guess.
Old Jul 29, 2024 | 11:16 PM
Greg in France's Avatar
I think that Martin Robey has them (Part number C16757).
https://www.martinrobey.com/jaguar/e...nder-block/263
or buy these lovely stainless ones from ebay 30 quid for a car set of 24.
https://www.ebay.co.uk/itm/Jaguar-V1...-/335106965806
Alternatively, why not just screw the stuck nut and stud back in? Or just use a threaded rod of the same pitch as that of the inlet manifold and use nuts of the same pitch? There is no reason I can see for using a different pitch at each end of the stud. If you are worries a drop of loctite will do it.
Old Jul 30, 2024 | 04:17 AM
BenKenobi's Avatar
This is a shot of mine coarse is 1/4x20 in the manifold likely down to aluminium and fine for the nut 1/4x28. The nuts on these manifolds can come loose so I don't think a coarse threaded nut will help that, I do have some 1/4x28 brass nuts that I will try if these don't stay tight. I will be assembling my manifolds in the next week or two.
J_C_R
Mar 12, 2020 02:38 PM
NCJagman
Jul 5, 2018 11:59 PM
NCJagman
Apr 14, 2018 08:30 AM
Paul Mason
Apr 21, 2013 10:38 AM
Kbudd
Mar 8, 2010 07:04 AM
