XJS Wheels
Old Mar 20, 2013 | 01:14 PM
Joe's XJS's Avatar
Default XJS Wheels
I have a 1990 XJS with 15" wheels (6.5" 28mm offset). Does anyone know if 16" XJ6 (7" 33mm offset) wheels will fit? Thanks!
Old Mar 20, 2013 | 01:36 PM
JagZilla's Avatar
It probably depends on the year of the XJ6. I have a set of the 17" slotted wheels from the '94-'97 XJR (X-300 platform), which fit perfectly, and will go on my '84 XJS when I finish it's current transformation project. I've heard that the later XJS wheels won't fit properly, and I'm not sure they are hub-centric, as are the wheels of the XJS and earlier XJ6s.
Hopefully, you will also get a reply from someone who is more familiar with the XJ6.
Old Mar 20, 2013 | 02:19 PM
Joe's XJS's Avatar
Default XJS Wheels
Thanks, my only concern is if they will be too wide and rub the body in the rear.
Old Mar 20, 2013 | 02:59 PM
Zar's Avatar
Zar
They should fit. I just bought some 20 spoke alloys that were used on the later XJS and XJ6. They are 7" wide with a 33mm offset and they fit my 87 XJS fine with a 225/60 16 tire. Any XJS wheel will work, no matter what year it came off of.
Old Mar 20, 2013 | 03:53 PM
Joe's XJS's Avatar
Great...thanks!
Old Mar 20, 2013 | 03:55 PM
Joe's XJS's Avatar
If you have photos, would love to see tham..........
Old Mar 20, 2013 | 04:09 PM
Spyhunter2k's Avatar
They should fit fine front and rear.
Old Mar 20, 2013 | 06:13 PM
Mkii250's Avatar
Here's some wheel/tire info: Rim and Tire upgrade Decision
Old Mar 21, 2013 | 08:07 AM
Hep320's Avatar
Default xk8 wheels
Here is my 1988 with XK8 wheels. Replacing radiator and tucking bumper so it looks like too much gap in front wheel. The wheels fit perfectly with only a 4mm spacer up front so the center can be used.
H20boy
Dec 24, 2024 03:23 PM
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
Armor6
Sep 14, 2015 07:56 PM
metalmarty
Sep 11, 2015 07:05 AM
