XJSC trim removal
Old Jan 18, 2021 | 12:06 AM
Bundy1's Avatar
Smile XJSC trim removal
Hi all - I have a 1986 XJSC that needs it's timber trim redone but I cant see how to remove it from the dashboard area. It appears to be screwed from behind and so I thought I would try to remove the dashboard itself but I can't see how that is fixed either.
I have acquired the workshop manual which covers most things but not this.
Can anyone provide a little guidance please?
Old Jan 18, 2021 | 12:46 AM
Greg in France's Avatar
The wood trim is just held in by pins going into friction-creating fittings. You have to VERY carefully, using plastic tools, lever it out. Start on a small piece (eg round the interior light switches) to get the hang of it.
The veneer is on a solid wood backing, about 1/4 inch thick, getting the tool behind the wood backing is important, and NOT bending the backing, or the veneer will crack off.
Old Jan 18, 2021 | 01:02 AM
Bundy1's Avatar
Thank you for such a quick reply. I will be carfull.
Regards
Wally
JayW
May 29, 2020 07:59 AM
XJR033
Oct 16, 2018 05:45 AM
sanchez
XJ40 ( XJ81 )
Mar 20, 2018 06:26 AM
jaglover123
May 1, 2015 10:22 PM
ajmac
Mar 21, 2010 10:16 PM
