XKS Unlimited remote bleeder system
Old Nov 7, 2018 | 01:35 PM
Matt300ZXT's Avatar
Default XKS Unlimited remote bleeder system
Has anyone used this one? Fosseway Performance is way over in England and would prefer to purchase something from a US based retailer and came across this one. I see they use the Speed Bleeder screws which I was considering purchasing, but figured the extra money for the remote setup may be worth it in the end.
Old Nov 7, 2018 | 02:19 PM
warrjon's Avatar
I used a cheap weed spray bottle from my local hardware store. I cut the spray wand off and used a large rubber stopper to jam into the fluid reservoir. Pump the bottle to 15psi or there abouts, too much pressure and the rubber stopper popped out.
Old Nov 7, 2018 | 02:27 PM
Greg in France's Avatar
They are fantastic. Assuming you have inboard brakes, they make bleeding far, far easier. It is not at all easy getting to the nipple on an inboard calliper, and the remote bleeders fix that problem, as well as making bleeding process itself easier.
Old Nov 7, 2018 | 02:30 PM
rgp's Avatar
rgp
I have a u.k version on mine but it has a bleed nipples one for each side, I have seen kits since then that link the 2 into 1 in retrospect I'd rather have had from the grovelling point.
Old Nov 8, 2018 | 01:10 AM
warrjon's Avatar
oops misread the thread, I blame Oldtimers
Old Nov 8, 2018 | 01:12 AM
MIne too.
Old Nov 8, 2018 | 07:26 AM
44lawrence's Avatar
I agree, I have this kit on my 91 & its the only way to bleed the rear inboard brake's without getting brake fluid all over a restored painted IRS
Old Nov 8, 2018 | 07:52 AM
katar83's Avatar
Never seen these before, fantastic kits! Some pics here:
Remote Bleed Kit for Jaguar IRS Brakes - Fosseway PerformanceFosseway Performance
I'll definitely be getting a set when I eventually get to mine
Old Nov 8, 2018 | 08:07 AM
Like me I suggest you get Fosseway's brass banjo fittings too, as then the flexible is far easier to run downwards. and far easier to fit to the calliper.
jagstuart
Jun 25, 2018 09:21 PM
Mkii250
May 21, 2014 06:11 PM
K.Westra
Oct 7, 2011 01:11 PM
SPP - British
VENDOR 'For Sale' Classifieds
22
Dec 1, 2010 01:44 AM
