@007 XKR door panel repair
Old Jan 22, 2025 | 01:51 PM
Zippymac's Avatar
Default 2007 XKR door panel repair
Not sure how many have issues with the glue de-laminating or plastic pieces breaking off door panels.
I found a gr8 3M product.
Panel Binding Adhesive: 08115 200 mL $58 US
Innovations 200 mL dual Component Cartridge Gun $48 US
I used this on the driver side panel and clamped and let set overnight and door is like new no rattles or looseness.
Do Need to be sure all surfaces are clean of any grease - break off any old glue that you can.
Old Jan 22, 2025 | 06:39 PM
Sean W's Avatar
I did a video on the repair. It''s fairly common. Most guys start with a heat gun or hair drier to soften the glue and press it in place. I did this:
https://www.jaguarforums.com/forum/x...6/#post2332407
Old Jan 23, 2025 | 08:33 AM
Zippymac's Avatar
Thank you - well done - I have used heat guns to revitalize plastics in the past, but the glue on my panel was hard and crumbling and several plastic retainers were cracked so Epoxy panel bond was the best solution to my situation. This is on the backside of the panel not the interior side but the back side of panel.
DlsXK
Mar 11, 2023 06:15 PM
miamijag
Jun 20, 2015 07:15 PM
scardini1
May 17, 2014 09:49 PM
bill586
Sep 2, 2013 11:10 PM
lockgirl
Apr 16, 2008 06:54 AM
