07 XKR A/C not blowing cold, hot on passenger side
Old Jun 30, 2013 | 02:20 PM
MsBee's Avatar
Exclamation 07 XKR A/C not blowing cold, hot on passenger side
I have a 2007 XKR conv. There is a noticeable difference between blowing temps of driver and passenger. The driver side is cool but not cold but the passenger side blows warm/hot. I'd almost say that it's not a/c at all, just vent blowing in outside air, but considering on some days it's 110 out it seems that the a/c must be working at least a little.
I have scoured the forum looking for what/how to test before I take it to the mechanic... any suggestions? Should I actually hear the compressor kick on? Any fuses to check? This doesn't seem to be a freon level issue because is blows cool on the drivers side? Blend door sticking problem?
Old Jun 30, 2013 | 02:35 PM
Holeshot's Avatar
I've got the same problem!
Old Jul 1, 2013 | 10:44 AM
jleuz1's Avatar
I had the same thing. There was a leak in one of the hoses. Replaced hose and all has been good for last 2 years. Rep told me that when system is beginning to fail, passenger side vent is the first to blow hot.
Old Jul 1, 2013 | 11:25 AM
amcdonal86's Avatar
What hose are you talking about?
Old Jul 1, 2013 | 01:29 PM
jleuz1's Avatar
Here is what my invoice says:
Concern: Customer states A/C is blowing out warm air, started on passenger side and is now warm on both sides.
Causes: Liquid line leaking
Correction: Connected IDS NO Codes for A/C system, connected AC machine, found to be out of refridg dye, tested AC system found liquid line leaking, replace line vac and recharge system.
Parts:
JAG C2P3507 Hose Air
JAG R134RC R134 Recycled
Looks like this particular hose was about $160.00 and there was about 3 hrs labor to test, diagnose and replace. Luckily this was still under factory warranty.
Maybe you are just low on refrigerant, If I was out of warranty I think I would try that first.
Hope this helps.
Jack
Old Jul 3, 2013 | 02:15 PM
MsBee's Avatar
Parts:
Hope this helps.
Jack
Thanks for your detailed response. This gives me a good idea of what to look for. Anyone know if I should actually hear the compressor kick on when I turn on the a/c? Also, is it normal to feel some cool air if the a/c isn't functioning at all? I would think 'vent' only would be hot outside air. I'm hoping the fact that I have some cool air means my compressor is working...
Old Jul 3, 2013 | 02:28 PM
07XKJaguar's Avatar
The a/c compressor runs all the time. It says this in the owners manual. I think it will default to hot on pass side when the pressure drops on the system(I know it does on other makes). A simple freon sniffer should help you figure out where the leak is coming from. Mine did the same thing after I had the thermostat replaced. They never really told what they did only repaired it.
Old Jul 3, 2013 | 02:37 PM
amcdonal86's Avatar
Doesn't the A/C compressor not run if you put it on "Econ" mode?
Old Jul 3, 2013 | 05:53 PM
Hailers's Avatar
Yep. No run in ECON.
Original poster...........have you tried ramping the passengers side up as high as it will go, then as low as it will go and seen if there's a temp changed?
YOu might try ramping the drivers side all the way up and then all the way down to see if there is a dramatic change in temps. IF there is a definite sense of COLD air coming out the drivers side then you know the a/c freon/compressor is ok.
In case you didn''t know..........go to the screen and select Climate. The on the right side of the screen you will see where you can turn the a/c compressor off by selecting ECON. My memory isn't all that swell, but that's the way I remember it. Frankly I turn the a/c to ECON during the fall/winter. No need for it imho. If it gets hot...........turn it back on.
Old Oct 18, 2016 | 02:03 PM
n1068d's Avatar
Had same problem on my 1998 XJ-8. Refrigerant was one pound low. Causes the AC to perform poorly. Noticeable difference in air temp coming out of main dash panel vents...driver's vent cooler than passenger side. When refrigerant was added, problem disappeared.
Bowman
Sep 15, 2015 06:54 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
user 652867429824
Sep 5, 2015 12:53 PM
OkieTim
Sep 2, 2015 12:48 PM
