2007 Rear "lift gate shelf"
Old Mar 8, 2017 | 03:43 PM
jbretthorton's Avatar
Default 2007 Rear "lift gate shelf"
Been searching for this, could not find anything about it, so I am sure I am just calling it by the wrong name....
I am talking about the rear trunk "shelf" that is removable, that attaches to the lift gate itself.....
Mine will not stay secured and in place for more than a day. Is this a common problem and are there recommended fixes by chance?
Thanks guys
Old Mar 8, 2017 | 04:58 PM
kj07xk's Avatar
I recall seeing a thread about this, some time ago, with some DIY fixes. Try searching, its here somewhere, maybe try 'package shelf'.
Edit: Found it ("parcel shelf").
https://www.jaguarforums.com/forum/x...solved-100517/
Old Mar 8, 2017 | 07:26 PM
Fstbmw1's Avatar
Thanks guys
I had the same issue a couple of yrs ago. I placed some electrical tape around the 'grommets' that then fit into the holes on the trim panel. No issue since! The holes seemed to have gotten a bit enlarged over time. Good luck.
Old Mar 8, 2017 | 09:24 PM
Thanks guys.... yeah tried the electrical tape fix, but not as effective as before.
Old Mar 9, 2017 | 09:21 AM
Sean W's Avatar
https://www.jaguarforums.com/forum/x...t-stay-164640/
This one has the replacement part #
https://www.jaguarforums.com/forum/x...stener-129838/
Old Mar 9, 2017 | 05:06 PM
Thanks!
Old Mar 16, 2017 | 12:27 AM
michaelodonnell123's Avatar
Here is what I wound up doing:
1. Remove shelf and bring it into your house
2. Remove each clip/stalk from all four corners
3. Now you have a hole in each corner [this is good]
4. Get 4 zip ties and go back to the car
5. Slip the zip ties through the holes of the shelf and through the hole of the trunk lid for each corner
6. Firm up the zip ties. Problem solved.
Old Mar 16, 2017 | 11:06 AM
Fstbmw1's Avatar
Agree that problem would be solved, and probably will never reoccur, however, I don't think it would look all that great.....but definitely problem solved.
Old Mar 16, 2017 | 11:12 AM
sov211's Avatar
A much better solution is to fit a plastic or metal washer to effectively create a reinforced area around the hole. It costs almost nothing and works perfectly. I did this on my car 5 years ago!
Old Mar 16, 2017 | 11:17 AM
Use clear zip ties. Not one person ever said to me me...'hey that looks really bad'...
Old Mar 16, 2017 | 11:48 AM
jimbov8's Avatar
Taken from another forum;
Problem solved !!!
I had a good look at these plastic dowels and realise they have a rubber expandable washer sleeve which grips the hole when the plastic levers are pushed flat and can be adjusted with the plastic nut to make them grip more. Now I worked out how the dowels are designed to work the shelf stays in place as it should. The previous owner of my car had the same problem as there was tape around the plastic dowels and I expect many owners glue the fixings, not realising a small adjustment is all that is needed.
Free fix and no glue required.
Hope this helps.
Old Mar 16, 2017 | 12:33 PM
Problem solved !!!
Hope this helps.
Yeah I did that and it still flopped out. Zip ties my friend.
