2007 - XK - Air Compressor Tick or Antennea?
Guys't looked at the source yet but th
Just bought an XK - really nice shape but a few things to work on. When I shut the car off - I hear a tick/tick...from the rear. I haven't looked what the the source of it is yet, I was thinking this may be an air suspoension and this is a compressor tick or I dont know yet. Ticks for about 15 secs or so and stops. Maybe on startup too - but I have only noticed it when I turn the car off. Any help would be appreciated.
Other issues that I see some video's on are stuck ASL button and missing glove box button to open.
Hi M1. Welcome to the forum. The XK doesn't have air suspension, but your 07 does have a telescoping aerial antenna. Quickest way to determine if it is the antennae is with the radio on, shut off the car and get out quickly. The antenna will collapse about 5 seconds or so after you turn off the car. As you watch it, listen for your noise and see if they coincide.
Get some practice - post an INTRO.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Hi - just wanted to follow-up on my ticking noise. This is coming form the power antenna. There is a gear inside it as I understand if from a used parts dealer that is causing this. I just took the fuse out for now and will leave it down. FM is supposed to work well with it down, just a loss of AM mostly. I'll get around to fixing / replacing this at some point. Thanks for the help!
