2007 XK antenna motor
Old Feb 5, 2019 | 02:07 PM
JTC's Avatar
JTC
Default 2007 XK antenna motor
Looking for new or used antennae motor
part: C2P6419. Help
Old Feb 5, 2019 | 02:17 PM
110reef's Avatar
I found an oem one on ebay for $450.
However, if you search on ebay for "power antenna 2007 XK", you will find plenty of items that say they will fit, for $35 or so shipped.
I am sure they are not an exact duplicate, but will probably work.
After dealing with my Toyota Camry and the my Mercedes C220 power antennas for a long time, this is exactly why I bought the 2008 XK over the 2007 XK, to not ever have to worry about power antennas again.
Old Feb 6, 2019 | 03:05 AM
Welcome to the forum JTC,
That P/N has been superseded by JLM21920. Forum Sponsor S N G Barratt list it at $426.03:
https://www.sngbarratt.com/us/#!/Eng...4-cb4c7eca7215
S N G Barratt offer forum members 10% discount on most parts.
Old Feb 6, 2019 | 01:46 PM
JTC's Avatar
JTC
I was told by my jag dealer that this new part requires wiring reconfiguration.
Additional labor plus the part prices out to $1,500. Wow.
Do i have the correct info?? Was advised just yesterday by service advisor.
This is why i am seeking a new or used oem part c2p6419. I believe i can actualy install myself.
I know the part is located behind the top motor -- which will have to be removed in order reach the antennae motor.
All this from a car wash that failed to lower the antennae.
Thanks for the help.
Jack
Old Feb 6, 2019 | 02:36 PM
kj07xk's Avatar
Jack
Oh, is the motor broken, or just the retractable antenna? The antenna can be replaced for much much cheaper. Do a search and you can find info on it.
IIRC, I bought one a few years ago, just to keep as a spare.
Old Feb 6, 2019 | 02:59 PM
kj07xk's Avatar
If it is just the mast, see this thread:
https://www.jaguarforums.com/forum/x...nt-8478/page2/
The last posting lists a part number A008-DBC2200 from antennasrus.com (the link didn't take me anywhere), but you can google that part number, and I found it on amazon, and purchased one of them.
Amazon Amazon
Old Feb 6, 2019 | 03:08 PM
kj07xk's Avatar
https://www.amazon.com/AntennaMastsR.../dp/B00JFGV9S2
In looking at the related items on that amazon page, it looks like this mast is a better fit (and the seller did answer a question in that it does fit the 2007 XK and XKR).
https://www.amazon.com/AntennaMastsRus-Power-Antenna-Compatible-Jaguar/dp/B00JQQR8B8/ref=pd_cp_263_1?pd_rd_w=KueOR&pf_rd_p=ef4dc990-a9ca-4945-ae0b-f8d549198ed6&pf_rd_r=9JAWNC4NP9Y2QTAH8ZHV&pd_rd_r=668105fb-2a51-11e9-b139-8fc39df8cf8c&pd_rd_wg=XOftg&pd_rd_i=B00JQQR8B8&psc=1&refRID=9JAWNC4NP9Y2QTAH8ZHV https://www.amazon.com/AntennaMastsRus-Power-Antenna-Compatible-Jaguar/dp/B00JQQR8B8/ref=pd_cp_263_1?pd_rd_w=KueOR&pf_rd_p=ef4dc990-a9ca-4945-ae0b-f8d549198ed6&pf_rd_r=9JAWNC4NP9Y2QTAH8ZHV&pd_rd_r=668105fb-2a51-11e9-b139-8fc39df8cf8c&pd_rd_wg=XOftg&pd_rd_i=B00JQQR8B8&psc=1&refRID=9JAWNC4NP9Y2QTAH8ZHV
Old Feb 6, 2019 | 03:37 PM
Cee Jay's Avatar
OR, get a tape-on strip antenna for inside the boot somewhere, hook the coax to that, then remove the ghastly whip antenna and guts, plug the hole in the wing, then be happy about it.
Old Feb 6, 2019 | 04:41 PM
kj07xk's Avatar
Yeh, there's a thread or two out there on that solution, one suggesting (and using) a marine antenna. Think I got one of those too, thinking I might pull the fuse for the antenna, but haven't done that, as I've found that I've rarely turned on the audio anything, but rather listen to the beautiful tune coming from the rear of the car.
Old Feb 6, 2019 | 05:43 PM
..... I've rarely turned on the audio anything, but rather listen to the beautiful tune coming from the rear of the car.
And there was I thinking I'm the only one. Last time the audio was ON was at the Dealer to check it worked.
Old Feb 7, 2019 | 03:42 PM
SLazz's Avatar
Me too. I only listen to the engine and the exhaust note. That's music to my ears.
Old Feb 8, 2019 | 12:01 PM
JTC's Avatar
JTC
I had a new mast installed. When the radio is turned on, the mast rises right up.
When the radio is turned off, there is a 5+ second pause. The mast then descends down and slows to an almost stop a foot above the fender. It then rachets down with the noise of slipping gears. It's a very noticable grinding sound. The mast finishes its descent in 3-5 seconds. The assumption by the Jag dealer is that the gear in the motor is stripped.
Not my case, but I understand that there are other occasions where the "tail" of the old mast geaar thread breaks off in the motor and the new thread doesn't fully reach its end position. In that case, the mast will not fully descend.
I'm currently looking into area junk yards. Still "no cigar."
Thanks for your help.
Jack
Old Feb 8, 2019 | 03:05 PM
Sean W's Avatar
generic motors work fine. Also 95 miata is a viable replacement I read somewhere on here.
Old Feb 8, 2019 | 03:14 PM
sov211's Avatar
Jack
The pause before retraction is programmed on purpose to prevent excessive wear in the case of stop/start situations...this is not related to the modern engine start/stop systems. The pause has been a feature of all Jaguar electric aerial units since 1980 at least. It is not a malfunction.
Old Feb 8, 2019 | 04:46 PM
kj07xk's Avatar
Mine has a delay before descending, so that is not a problem.
Since there is no ‘grinding’ on the initial descent (or is there?), but only on the final leg, I’d suspect that the cogs on the mast tail were stripped at that point, rather than the motor gear, which ran fine on the first part of the mast tail.
Old Feb 21, 2019 | 12:34 PM
JTC's Avatar
JTC
My problem is solved.
Found a junk yard with a 2007 XK totaled with FRONT end damage. The rear end with an antennae motor was my salvation.
Before removing the old motor, we ejected the antennae mast. NO damage tt he gears on the plastic thread.
FYI, folks, removing that motor is not easy, Requires removing the right rear tire -- then the under fender plastic liner -- all to get at two bolts that connect to a metal base bracket for the antennae. You also have to remove the casing that surrounds the top motor that sits in front of the antennae motor -- inside the trunk.
End of day, "new" antennae motor -- with a mast -- works perfectly. Part $300. Labor $40. (local mechanic) I was really fortunate.
NOTE: IMPORTANT. New part from Jaguar for this 2007 vehicle is not "like for like." New part will work but it requires wiring corrections. Jag dealer quote for new antennae motor - parts and installation -- $1,500.
SarosiMartin
Feb 13, 2019 03:43 AM
Sean W
Jan 25, 2019 03:00 PM
stevemcwilliams
Jan 18, 2019 07:01 PM
BC XJS
Jan 18, 2019 04:49 PM
chrisleg
Jan 3, 2019 02:37 AM
