2007 XK - Overheating - water pump replacement ??
Old Jul 15, 2012 | 06:29 PM
plums's Avatar
Anyone seen the Gates brand pump in the flesh to be able to say metal or plastic impellers?
Old Jul 15, 2012 | 10:37 PM
CleverName's Avatar
Originally Posted by tarhealcracker
Were it me - I would subscribe to AllData "one of our sponsors" before diving into this job. The front end of this engine is no big deal but it ain't like your old Chev 350 and the procedures to access and service the water pump need to be observed.
Just an FYI, (and not intending to detract from our sponsors) most our Public Library's provide AllData free of charge.
Vince
Old Jul 16, 2012 | 08:50 AM
Brutal's Avatar
does your local library have late night hours or web access to alldata. I dont know about you but I like to access stuff as I go anytime day or night
Old Jul 16, 2012 | 09:44 AM
ooootis's Avatar
Originally Posted by plums
That would be too brutal altogether
That hurt LOL
Old Jul 16, 2012 | 10:43 AM
CleverName's Avatar
Simply passing on useable info Brutal. What forum member choose to do with it is their business.
Vince
Old Jul 16, 2012 | 12:38 PM
tcharron's Avatar
Originally Posted by 2007 Rick
Don't know if I missed it but did you check to make sure the fans are coming on, as they should, at low speed and also have you checked the radiator to make sure it's not plugged ?
The fans seem to be operating. I hear the fan running at overheat conditions at high speed after the car is turned off. I always assumed that if it runs at high speed it must work at low speed too.
I haven't checked the rad for being plugged. I know that may be an issue if my thermostat housing problem caused a piece to lodge in the rad.
Old Jul 30, 2012 | 10:00 AM
tcharron's Avatar
So, with the help I've received from this forum, I was able to replace my water pump on Saturday.
Ended up draining the coolant, removing the air intake (which required loosening the brake fluid reservoir), removing one coolant hose (directly above/in front of the water pump), removed the belt, pulley, and then the pump and (metal) gasket.
I had avoided removing the thermostat housing and throttle body, so it was all a tight squeeze. After removing the old pump, I was surprised to see that it all looked ok (including impeller). I then looked down as best I could and felt in/around the ports. I found a small bit of plastic (about the size of a nickel -- see pic). I presume is an old part of the previously cracked (and dealer replaced) thermostat housing. It was sitting just in front of the pump, so I think it fell out of one of the ports. I couldn't find anything else in the area. This was my "AHA" moment. I did not try to look into the ports with a mirror.
I installed a new pump with (paper) gasket and put everything back together. I filtered the coolant and found a few small bits of debris (nothing larger than a grain of sand).
Once everything was back together I didn't have time to do a proper test and put the car in the garage.
Next day, wife took the car out. No warnings came up but it was still hot (as determined by an OBD tool when she returned). It was at 106 C. I know that the jaguar "overheating" light comes on at 119C -- there's no reason an idling car should be at 106. It was at this point that I noticed that it had lost some coolant (overflow was down about 2 inches). Sure enough, there was also some on the garage floor too. It looks like I was too timid about tightening the water pump bolts. I imagine that most of the coolant was lost during driving due to the higher pressures that would have been present.
I hope to find an hour or two one night this week to tighten the water pump bolts. I am not sure if I can do it this time without draining the coolant or not. If I do need to drain coolant, I'll remove the pump again and see if I can find any more debris in that area.
I hope that the low coolant was the problem and not that there is another blockage in the system.
So here' my question for the forum this time -- would a 2 inch coolant drop (as seen at the overflow) cause this kind of overheating?
Attached Thumbnails 2007 XK - Overheating - water pump replacement ??-img-20120729-00551.jpg
Old Jul 30, 2012 | 11:56 AM
  #28
amcdonal86's Avatar
Glad you seem to have found the problem! I hope it all gets sorted quickly!
Old Jul 30, 2012 | 03:55 PM
Brutal's Avatar
Thats the broken inner piece off the t stat housing i was talking about earlier. Its probobly the only piece as they tend to get stuck in the wp cavity where you found it impeeding flow. As far as the coolant level you had/have trapped air. I always like to run the car after a repair like this then let sit overnight and cool and top the reservoiir back up.
Old Jul 31, 2012 | 07:31 AM
  #30
tcharron's Avatar
When I did the work earlier, I reused all of the fluid and didn't lose any material amount. That's why I don't think I had an air pocket.
I checked the overflow tank this morning. While it was down 2 inches when hot, it was only about 1 inch down when cold. I topped it to the max line and we'll see how much it leaks. I'm trying to determine if I should go to the effort of getting access to tighten the bolts, or if it will be futile. Seems like a minor amount of fluid loss to cause overheating.
Old Aug 2, 2012 | 02:30 PM
  #31
2007 Rick's Avatar
Default Overheating
It looks like you've done your homework. It would seem the only thing left is the radiator. I also have an o7 XK and a 1-2 in drop in coolant will not cause that overheating issue. As I've not had to look into it I don't know if the radiator can be boiled out at your local shop. That being said the price of radiators (for most cars) is inexpensive. Napa should be able to handle it.
Old Aug 3, 2012 | 06:17 PM
  #32
tcharron's Avatar
I'd be mildly surprised if the rad plugged up at 40k unless something found its way to it (however, I'll settle for any correct diagnosis at this point). The coolant looks good, and when I drained it I filtered and found nothing -- doesn't really sound like a plugged rad. If it was plugged, it would appear that someone replaced the coolant (and maybe didn't solve whatever problem the rad had?)
Once heated up, I noticed that the top rad hose was hot and bottom one was cool. Does this mean that the rad is doing its job?
With the cracked thermostat I had, where else could the debris end up? I found one piece down by the water pump. Is it possible that something could end up elsewhere, like deeper in the engine?
When I idled the car for 20 minutes, the engine warmed up (quite slowly) to 95. The AC was on. I then flipped on the heater to full and the temp dropped quite quickly to 85. It seems that the heater matrix is working - not sure if this means anything else?
Lastly, At what temperature would you expect an idling xk to 'level out' at? I think that the thermostat opens between 80 and 95? Does this mean that this is where you'd expect the engine to be if not driven hard?
Sorry for all the questions -- I'm learning as I go here!
Old Sep 5, 2012 | 12:00 PM
  #33
tcharron's Avatar
Progress! And a request for advice...
I had tried removing the water pump a second time to see if another piece of plastic had found its way down there, but found nothing. The car was still overheating, but at least much less quickly and more easily 'fixed' if I revved the engine at 2000 rpm.
Took it to another shop. They did a rad flush with no effect. Then they started taking it apart. Despite my having paid a Jag dealer nearly $500 the first time I had it in, it turns out that they didn't replace the entire thermostat housing. They said it was cracked, but only replaced the upper cap. This new shop found that the lower part was also cracked badly. Part has been ordered, and for good measure I've asked them to do a backflush of the block.
I've asked them to bag the defective parts. Should I take this up with the original dealer who obviously didn't replace the housing properly? Costs were $60 coolant, $87.05 for gaskets, $70 for housing, $135 diagnostics (pressure test I think), and $270 for 2 hours labour. Seems like a ton of bills to have half a job done, and it really threw me off "diagnostic wise" as the one thing I relied on being right was the thermostat and housing!
Sprayall
May 30, 2021 08:13 AM
Russ Graber
Feb 23, 2019 11:59 AM
Raul Lara
Sep 14, 2015 07:31 PM
alpecsa
Sep 7, 2015 11:55 AM
Sprayall
Sep 3, 2015 07:49 PM
