2007 XKR. I want to disconnect antenna.
Old Sep 11, 2008 | 06:15 PM
lwilliams's Avatar
Default 2007 XKR. I want to disconnect antenna.
Would anyone know how to disconnect antenna in the trunk of the car. It looks bad going up and down all the time and only use satellite and local stations anyway. I appreciate the help in advance.
Bill
Old Sep 17, 2008 | 04:28 PM
cvprez's Avatar
Default RE: 2007 XKR. I want to disconnect antenna.
ANyone have any input on this, I was thinking of doing the same thing since I usually listed to ipod and the antenna goes up whenever the radio is period
Old Sep 18, 2008 | 04:56 PM
ScootMan's Avatar
I pulled the 10 amp fuse ( position F4, fuse box , center rear seat).......problem solved......Sat/FM/AM all works fine......maybe slight diff in FM reception...but I rarely use.
Old Sep 18, 2008 | 10:51 PM
H20boy's Avatar
Theres a procedure for installing a switch that will fit perfectly in the spot on your lower left knee in that dash knockout, and you decide when the antennae is extended. Requires pulling the radio out though, if you're up to it.
Old Sep 19, 2008 | 11:19 AM
lwilliams's Avatar
Thanks for the input. I took it to the dealer and he showed me the antenna plug in the trunk. There's a compartment on the right side in the trunk and just pull it open , reach in to the base of the antenna and unplug the yellow plug. It worked perfectly. Now if needed just plug it back in.
Problem solved. Thanks for help.
Old Sep 24, 2010 | 04:22 AM
stepp's Avatar
thanks for the info
Old Sep 24, 2010 | 09:03 AM
WldCat's Avatar
Oooh, I'm doing this over the weekend! (The antenna strikes the low ceiling in my building's underground garage.) Thanks for the info!
Old Sep 28, 2010 | 08:00 AM
WldCat's Avatar
Got a photo of the plug? I looked at mine and didn't see the yellow one you describe. Saw a red one though...
philwarner
Jan 31, 2016 09:36 AM
Dave1109971
Dec 15, 2015 06:16 PM
Sonnyblack
Oct 4, 2015 05:42 PM
Ragn0r
Sep 29, 2015 10:38 AM
Ragn0r
Sep 28, 2015 06:14 PM
