2008 Jaguar XKR - Proper Oil For Supercharged Motor
Old May 11, 2021 | 06:45 PM
smose2400's Avatar
Default 2008 Jaguar XKR - Proper Oil For Supercharged Motor
If you speak with Mobil 1 or Castrol regarding which of their product they recommend for your 2008 Jaguar XKR, they will tell you they don't have an oil for you. Their internal systems say the car requires the Ford designation WSSM2C913B, (an old number that a Ford dealer could not find in his system). My handbook only states: Castrol API SM and Ilsac GF-4, 5W-30 is preferred. I also have a 2007 Jaguar XK, with same 4.2L engine, and both companies have a variety of oils available. I have discovered that Valvoline has a Synpower European 5W-30 full synthetic, but have not found it in my area. Apparently some Jaguar dealers use Castrol Edge 5W-30. Motorcraft (Conoco Phillips) has a 5W-30 semi-synthetic oil that has an updated WSS number designation which does not match the old number.
Can anyone shed light on this?
Thanks.
Old May 11, 2021 | 07:38 PM
Cee Jay's Avatar
Oil is oil, as long as it's good. Please don't start another thread on this, there are dozens already and all they do is cause discourse!
https://www.walmart.com/ip/Valvoline...5-QT/775524529
Old May 11, 2021 | 11:57 PM
gkubrak's Avatar
Refer to your oil filler cap for the recommended oil.
Old May 13, 2021 | 09:32 PM
UKWyldcat's Avatar
Castrol Edge, 5W-20 is all you need. No other oil will give you any better engine protection or performance.
Old May 17, 2021 | 08:27 AM
gkubrak's Avatar
5w-20 is not correct for the 4.2 motor.
Old May 17, 2021 | 09:54 AM
Cee Jay's Avatar
I live and drive in 100+ Fahrenheit weather. I'll not use 0w-anything.
Old May 17, 2021 | 12:25 PM
guy's Avatar
guy
The 4.2 Owner's manual states...
File Type: pdf
JaguarXJ8L2005
45
Feb 17, 2023 07:56 PM
mghirsch
Oct 8, 2016 09:17 AM
prodigy215
Jul 31, 2016 05:48 PM
powerhouse
Aug 15, 2015 11:41 AM
zvonas
Aug 27, 2008 01:00 PM
