2008 XKR Code P0128 and P050B
Old Jan 1, 2016 | 10:48 AM
David's XKR's Avatar
Default 2008 XKR Code P0128 and P050B
2008 XKR Coupe 60k miles.
I got a couple of codes recently. RPM's surge between 500 and 800 at idle. Battery was original so I got a new one and codes came back after a few trips. I found P0128 and will be getting a thermostat. But a search for P050B turns up nothing. Google it and I find a link for a 2006 XKR with TSB 30313 says ECM needs a re-flash. It's the same symptom but there's no reference connecting it to a 2008.
Old Jan 1, 2016 | 11:08 AM
JagV8's Avatar
It's not likely to be false.
Old Feb 25, 2019 | 12:21 PM
gkubrak's Avatar
Did you ever diagnose the P050B code?
Old Feb 25, 2019 | 12:49 PM
110reef's Avatar
I am sure the code is P0508. That would be idle air control valve.
Old Feb 25, 2019 | 01:12 PM
gkubrak's Avatar
The P050B is cold start performance which is what I got this morning. And I do remember a TSB for it on other models so I'm wondering if the OP solved that.
Old May 31, 2019 | 10:43 AM
viper1996's Avatar
Me too any ideas anyone? Didnt do it until dead battery...
Old May 31, 2019 | 10:54 AM
gkubrak's Avatar
I haven't had that code since winter. I think it's tied to the P0101 i'm getting due to a vacuum leak. It makes sense ... at colder temps, the air is more dense so a vacuum leak would be most noticeable during cold starts. That's probably what triggered the P050B. Still waiting on a smoke machine to find the actual source of my vacuum leak.
rags87
Mar 17, 2016 05:42 AM
Olopez16
Jan 10, 2016 06:24 PM
Lawrence Thompson
Jan 4, 2016 12:52 PM
jokerswild1
Jan 2, 2016 08:12 PM
frogeye621
Dec 30, 2015 05:42 PM
