2010 XKR convertible Cold Air Intake
Old Mar 27, 2021 | 07:06 PM
Joseph Giovinazzo's Avatar
Default 2010 XKR convertible Cold Air Intake
Hey guys, my dad recently purchased himself a 2010 jag xkr convertible. When you get on the gas you can’t really hear the supercharger... i was wondering if anyone’s got any good suggestions for a cold air intake? I haven’t found much info online reguarding a 2010 xkr. Thanks!
Old Mar 27, 2021 | 08:49 PM
Stuart S's Avatar
There's reason why you won't find much info on cold air intakes for the XKR. Unless you're going to track your car, the factory intake is just about as good as it gets.
https://www.jaguarforums.com/forum/x...intake-213341/
Forum member jahummer tracks his car and custom built his cold air intake:
https://www.jaguarforums.com/forum/x...-works-200931/
If you want to hear the supercharger more, simply remove the Engine Appearance Cover. The foam lining inside that cover muffles the sound somewhat. For more exhaust noise, drive around in Dynamic Mode and use the paddle shifters. Iif you want the noise without the hassle of manual gear changes or the firmer ride of Dynamic Mode, pull Fuse 19 to keep the active exhaust valves open. If that's still not rowdy enough, remove the front resonators and replace them with an X-pipe.
https://www.jaguarforums.com/forum/x...se-19-a-87400/
Old Mar 27, 2021 | 09:00 PM
Stuart S's Avatar
Joe -
Welcome to the Forum. Read this - it's important.
https://www.jaguarforums.com/forum/n...ned-up-241802/
Yoor father should join this Forum. You're welcome to stay even though you don't own an X150. Note that it's helpful if your Public Profile includes your state and city, and details about your car. A signature block is also helpful so others know the year and model X150 and location.
Stuart
UKWyldcat
Mar 24, 2021 09:51 AM
pennstater
Sep 26, 2020 09:08 PM
User 070620
Aug 20, 2018 04:52 AM
dominic005
Dec 27, 2013 04:00 AM
JK_XKR
Aug 22, 2012 09:45 PM
