2012 XKR : Odd LED. Comes on with brake light
Old Feb 3, 2018 | 06:21 AM
LockNumber25's Avatar
Default 2012 XKR : Odd LED. Comes on with brake light
Just picked my car up, absolutely delighted. Just noticed that there is a small red LED smack in the middle and in front of the dash board, behind the steering wheel. Comes on when with the brake light - it's really annoying. Looks stock but can't imagine it is or why it would be there.
Anyone got this in there car? Any thoughts why on earth there is a LED that comes on when you hit the break?
Cheers.
Old Feb 3, 2018 | 06:28 AM
jagtoes's Avatar
Cheers.
Looks like you have my twin car. As for the LED I don't have that in my car unless I'm not looking in the right place. If you can take a picture but I don't know of this feature unless it's required in Europe or the UK.
Old Feb 3, 2018 | 06:42 AM
This is the little bugger.
Old Feb 3, 2018 | 06:59 AM
jagtoes's Avatar
Nope , don't have that in my car and I would say it is an add on of some kind . Maybe it was for the previous driver to tell if the brake lights were working. I would ask the previous owner or the dealer that sold you the car why it is there and what did it do. Does it light or flash after you lock the car. Is it some kind of anti theft add on feature. Just my thoughts.
Old Feb 3, 2018 | 07:19 AM
pwpacp's Avatar
Since it is associated with the brake pedal, is it possible the PO installed it to indicate positive pedal compression when starting the car?
Old Feb 3, 2018 | 07:34 AM
Just had a look and it's not flashing or on with the car being locked so doesn't appear alarm related.
@pwpacp I think you're right - but I can't image why you would do that?
Old Feb 3, 2018 | 07:48 AM
pwpacp's Avatar
It is something I thought about once on my 1st XK as I found the start sequence was kind of wonky. Pushing start first then pressing the brake the pedal would sometimes not build enough brake pressure on a switch to intiate engine start. After reading several posts on this forum, I found that changing the sequence to pedal then button resolved the issue thus negating the need for a visual indicator.
Old Feb 3, 2018 | 08:30 AM
Ranchero50's Avatar
Maybe someones wife drove with her foot on the brake and the add on light was a reminder to keep off it?
Old Feb 3, 2018 | 09:15 AM
Sean W's Avatar
Not sure of the value and if it's of no value to you, remove it or push it under the dash panel and plug the hole with a small with a cap.
Old Feb 3, 2018 | 09:17 AM
Sean W's Avatar
Also, this is your new baby. You need to post pics in a separate thread, or we will all assume you don't really have a Jag and you just downloaded a pic from the internet
Congrats on the new Jag and welcome!
Old Feb 3, 2018 | 11:29 AM
Stuart S's Avatar
I think you have it bass ackwards. Press the START button first, then tap the brake pedal. See my post #104: https://www.jaguarforums.com/forum/x...r-91426/page6/ Lots of other threads on this.
Old Feb 3, 2018 | 02:04 PM
pwpacp's Avatar
@Stuart, Yup you're correct! It is Start button then Brake pedal.....the wife's Lincoln is just the opposite which makes it confusing. Hope that doesn't trip up the OP.
Old Feb 3, 2018 | 05:26 PM
Thanks all. Adding removal of bizarre interior brake light to this list.
@Sean W - will post some pics soon. It's been pouring with rain all day and even though the car looks great in the wet I don't hold up much hope for my phone surviving the downpour while i snap it.
Old Feb 3, 2018 | 05:44 PM
You certainly do things differently in the US of A.
2012 XKR : Odd LED. Comes on with brake light-start.jpg
Old Feb 3, 2018 | 06:26 PM
Sean W's Avatar
So in other words, when in doubt, read the manual? Hehe
Old Feb 3, 2018 | 07:07 PM
pwpacp's Avatar
While the manual is text book while the forum offers advice from member's real life situations. Both are of great value.
Old Feb 3, 2018 | 09:11 PM
Stuart S's Avatar
Graham,
Yes, I know what the Owner's Handbook says, but that's not what my Service Advisor told me to do when my XKR wouldn't start while I was in my car and speaking with him after my car was serviced. He explained that I must have inadvertently pumped the brake pedal and to get it to start I had to "stand" on that pedal with extreme force to get it to start. To prevent this from happening again, he recommended pressing the START button first.
My car starts much faster, with just a tap on the brake pedal, when I press the START button first. Try it and see for yourself.
Stuart
P.S. With my method, my car starts fast. By the book, it starts half- fast.
Old Feb 5, 2018 | 04:23 AM
..... my Service Advisor ..... recommended pressing the START button first.
YES - I'm not disagreeing. I know it starts like that and why it does .........
2012 XKR : Odd LED. Comes on with brake light-ignition.jpg
Is there some kind of car starting Olympics in your neighbourhood?
The limiting factor on my departure time is waiting the several seconds for the gates opening and not shaving a tenth or so off the engine firing time.
Old Feb 5, 2018 | 11:30 AM
Ranchero50's Avatar
Pressing the start button wakes up the car. When the brake pedal is pushed first the car's systems are coming online while the starter motor is cranking. I've found I get less dumb stuff happening if I let the car wake up a second with the button before trying to crank it over with the brake pedal. It also seems to start faster.
Old Feb 5, 2018 | 12:08 PM
Hailers's Avatar
No. You apply brake pressure then press the start button. Common practice.
