2013 xk left headlight is dead
Old Aug 22, 2024 | 02:48 PM
WHB64's Avatar
Default 2013 xk left headlight is dead
Hi guys...
I scoured the internet and youtube looking for videos on headlight removal for a 2013 XK and did really find anything helpful.
Let me back things up first- I developed a coolant leak and had to have the water pump replaced. This is probably just a coincidence, but not my left headlight assembly is completely dead. None of the lights work. The fuse is good, I already checked that. It's almost like it's unplugged or has no power to the assembly but I can't find the plug to check that. Any tips and advice would be greatly appreciated.
Old Aug 22, 2024 | 03:20 PM
Stuart S's Avatar
@WHB64 This thread should help:
https://www.jaguarforums.com/forum/x...t-bulb-195931/
Also see the Service Manual, links to which are included in the Stickies at the top of this Forum:
https://www.jaguarforums.com/forum/x...guides-215509/
Hope this helps. If so, please click the button at the bottom right corner of the page.
Stuart
Old Aug 22, 2024 | 03:50 PM
McJag222's Avatar
First I would check the ground lugs behind the wheel and shock on the right hand side - just pull the wheel and see if the ground stud on the chassis member is corroded and or the individual lugs are still good. This is a common issue with the 2007-2009's.
Old Aug 23, 2024 | 05:03 PM
VideoTutor's Avatar
Don't know if this is any help. My XKR 2012 had right-hand day running light out. We could find no wiring diagrams that fitted the car and eventually found a junction that had fused out with most of the terminal completely corroded - looks like water got in it.
Old Aug 24, 2024 | 04:25 AM
Lothar52's Avatar
were you able to replace that connection? part number for the group?
Old Aug 24, 2024 | 07:50 AM
guy's Avatar
guy
That is unexpected and unfortunate. I have to attest that it has never happened to me and, I wonder how it could unless the connector was not fully connected or damaged and not replaced.
On the side where wires enter the connector, I have sealed many of the connectors with Starbrite Liquid Electrical Tape.
(Which is the reason that I am confident that no harm will come when I wash the engine bay)
Old Aug 24, 2024 | 04:52 PM
VideoTutor's Avatar
We could not easily locate an original connector. So rewired a non original.
jmurphy1972
May 28, 2024 05:43 AM
thebeeg
Apr 22, 2024 08:40 PM
Argon18
Jul 22, 2021 05:54 PM
wkb
Apr 7, 2018 09:14 AM
Arrigh
Feb 5, 2014 04:22 AM
