2013 XKR - Check Engine Light/Code P0456
Old Mar 24, 2020 | 11:26 AM
Barry Leftwich's Avatar
Originally Posted by guy
Never heard of that. I only use shell or sunoco.
for some reason,it makes my engine light come on.My car must have a dirty engine when i bought it cause i know shell gas is cleaning the gunk and my engine is sensing the gunk being cleaned
Old Mar 24, 2020 | 11:28 AM
Originally Posted by Sean W
yep, it's a top tier gasoline. Never had an issue with it either.
i think it's just my engine tho
Old Jun 29, 2020 | 07:23 AM
tygerman49's Avatar
Hey all,
It's been a while since I started this thread, but the ongoing pandemic has certainly affected all of our lives and slowed lots of things down. Anyway, I was finally able to get my Jag back to the dealer up in PA a couple of weeks ago to get the CEL/code P0456 looked at. I just got it back on Saturday.
The culprit: leaking purge valve. They replaced it and now no more code or check engine light.
I am very impressed with the car dealer. While they had my Jag, they fixed this issue, took out several door dings on both sides of the car, fixed the broken damper on the glove compartment and did an oil change it was due for...all for no charge. They've definitely earned a repeat customer, even though it's a 2 hour drive to get up to them.
Pat
Old Jun 29, 2020 | 09:30 AM
Sean W's Avatar
Thanks for closing out the post. This always helps the next person. If you have a chance, can you look at your invoice and list the part number for the purge valve? That will help others as well.
Glad it got sorted out for you.
Old Jun 29, 2020 | 09:46 AM
tygerman49's Avatar
Sean,
No problem. For everyone, here's the part that was replaced:
Purge Control Valve - Jaguar part # AJ811695
Looks like it would cost $140-150 if you had to buy it.
Pat
Old Jun 29, 2020 | 03:00 PM
MarkyUK's Avatar
And this is what that little sucker looks like:
https://www.ebay.co.uk/itm/Genuine-J...sAAOSwZ~pd3pPD
Old Jun 29, 2020 | 05:05 PM
Sean W's Avatar
pnguy28
Apr 11, 2019 06:48 AM
myironlung
Apr 15, 2016 12:26 PM
RichmondXK
Apr 8, 2013 09:04 PM
srpope80
Nov 17, 2011 04:06 PM
aholbro1
Apr 24, 2011 07:26 PM
