2013 XKR taillights and infotainment won’t shutoff.
Old Aug 20, 2019 | 12:50 PM
Sleeper RS's Avatar
Default 2013 XKR taillights and infotainment won’t shutoff.
I’ve noticed a few times the screen won’t shutoff and it hangs a jag logo. Now I’m having the corner brake lights stay on. My battery might be weak at this point from a few dead starts. I always unhook the battery and charge without vehicle connection. Any ideas? I’m attempting the hard reset procedure touching both cables together for 30 seconds and then a 30 minute nap. I don’t like the idea of touching the cable to a hot battery. Any recommendations as to what to do next?
Old Aug 20, 2019 | 12:59 PM
JackJohn's Avatar
You may want to have your battery checked out at Auto Zone or another auto parts retailer.
Old Aug 20, 2019 | 01:44 PM
Sleeper RS's Avatar
Sometimes the simplest answer is the correct one. Headlight switch was on parking lights instead of auto or off. Makes total sense and I’m an idiot...
Old Aug 20, 2019 | 02:02 PM
gkubrak's Avatar
What about the infotainment?
I had similar experiences with the screen either not coming on, or not going out.
One time the radio wouldn't turn off at all haha. Gotta love the good ol' Jag electronics
Old Aug 21, 2019 | 05:47 PM
George05's Avatar
2 Thinks spring to mind . battery is kaput or its a faulty relay
Old Aug 21, 2019 | 06:44 PM
sov211's Avatar
It is the battery. The battery...the battery....the symptoms are a perfect description of battery failure and its results in these cars.
Old Aug 21, 2019 | 07:07 PM
Cee Jay's Avatar
The OP said what the problem was, he had left the lights turned on. See post #3
Old Aug 22, 2019 | 03:12 PM
sov211's Avatar
Yes, that explains the lights but does not explain the touch screen issue - but low battery voltyage does.
Old Aug 22, 2019 | 04:34 PM
Sean W's Avatar
So if I'm reading this correctly, you're saying it could be the battery?
humor....
Old Aug 22, 2019 | 06:01 PM
Cee Jay's Avatar
Yes, that explains the lights but does not explain the touch screen issue - but low battery voltage does.
The lights ON will also explain the Low Battery Voltage.
cs81srq
Apr 5, 2019 10:03 AM
pbcs004
Jan 23, 2019 08:31 PM
William James
Aug 19, 2016 04:15 PM
TomServo
May 10, 2011 05:15 PM
Alwann
Nov 5, 2009 08:57 PM
