5.0 Drive Selector lock-out when hot stuck in park
Old Aug 21, 2025 | 09:26 PM
trkyam's Avatar
Default 5.0 Drive Selector lock-out when hot stuck in park
Anyone encounter this?
When its 95F hot car parked sunny day, selector hot to the touch
I start the engine and press the brake to shift out of park
And the lockout won't release to allow me to turn the drive
selector. After repeatedly playing with it and pushing the brake
eventually it is able to shift into reverse/drive.
This is the second time this happend, after I arrive at home
No issues, shifts perfectly out of park.
Old Aug 21, 2025 | 09:28 PM
trkyam's Avatar
Is the solenoid which activates the selector getting weak,
or is this purely a heat soak ssue?
Old Aug 21, 2025 | 10:10 PM
Speedmaster's Avatar
Interesting issue. I don't know the answer.
But what I wonder - and I don't know if they are correlated - but you mention starting the car and then pressing in the brake pedal. My car will only start with the brake pedal pushed first. And, gear selection occurs then too (when brake pedal is depressed.)
Old Aug 21, 2025 | 10:59 PM
trkyam's Avatar
Correct, brake gets pushed before starting engine, I start the car and let the AC cool me down a second and revs drop,
This is not a brake switch issue.
Old Aug 21, 2025 | 11:19 PM
Cee Jay's Avatar
Huh. I leave my top down in the sun sometimes and the ambient temps are right around 100f. Direct sun even, and I've never had this problem.
Maybe I'll do that less often if this may happen to mine. I'd not like that. I shall ponder possible causes...
Old Aug 21, 2025 | 11:34 PM
trkyam's Avatar
You can hear the actuator when in park and step on brake
I suspect its getting sticky in the heat
Old Aug 22, 2025 | 01:16 AM
xalty's Avatar
it’s a 15 year old jaguar rotary selector…..
if you have to ask if it’s broken it probably is
Old Aug 22, 2025 | 03:59 AM
trkyam's Avatar
Well its working fine now,
Maverick115
Jul 30, 2021 11:02 PM
Rlover
Mar 30, 2016 10:04 PM
LeoF-01515
XJ XJ12 ( X305 )
Jul 9, 2014 08:07 PM
YycXJS
Oct 10, 2013 09:09 PM
Jaguarpains
Dec 17, 2012 07:53 PM
