5.0 XK Low temperature thermostat install
Old Jan 31, 2023 | 10:58 AM
trkyam's Avatar
Default 5.0 XK Low temperature thermostat install
Good day everyone,
This past weekend I fitted a low temperature thermostat rated to open at 85c vs the 95c stock one.
After testing the thermostat successfully prior to install, I installed it and a new thermostat housing.
A few observations were made:
My original thermostat only has one resistant spring inside the housing.
The new thermostat has 2 springs inside the housing.
The original thermostat's spring is easy to compress
The new thermostat has a very stiff spring.
Results:
Car actually runs hotter than it used to staying steady around 95-98c highway and in traffic
but very consistent.
I understand the ECM must be repogrammed to kick fans on early to get better cooling from a low
temp thermostat however, on the highway I would expect my car to run cooler, not hotter.
I am considering putting in the stock 95c thermostat back in.
Thoughts?
Old Jan 31, 2023 | 11:16 AM
Joe7Bros's Avatar
I don't know if the 10c lower opening t-stat difference will cause a problem, but the ecm expects the coolant temp to reach operating temp, and will throw a code if it does not
Old Jan 31, 2023 | 11:36 AM
trkyam's Avatar
No codes were thrown, as I live in a warmer climate.
the engine runs hotter on the highway now..
Old Jan 31, 2023 | 02:04 PM
Joe7Bros's Avatar
Coolant circulating too fast, not in the radiator long enough to shed heat.
Old Jan 31, 2023 | 02:12 PM
trkyam's Avatar
My original thermostat housing was cracked internally, this is why I was changing it.
Would you suggest re-installing the factory 95c thermostat(came with the new housing) for better highway temps?
Old Jan 31, 2023 | 02:24 PM
Joe7Bros's Avatar
Yes, the t-stat housings fail; as far as the t-stat itself, if it wasn't overheating with the original t-stat, I would reinstall it, or a new correct temp one, if it was my car
Old Jan 31, 2023 | 02:29 PM
trkyam's Avatar
for informational purposes the thermostat I installed is this:
Amazon Amazon
Jet Performance 10167 Thermostat
Old Jan 31, 2023 | 02:37 PM
trkyam's Avatar
Anyone know software that can change the temperature the fans kick on via OBD2?
Popstacle
Jan 30, 2023 12:24 AM
garethashenden
Jun 19, 2021 05:21 PM
Rey
Apr 20, 2013 02:08 PM
dkeuper
Oct 12, 2012 04:54 AM
