5.0 XKR - how close to 300kmh?
Old Mar 27, 2026 | 10:52 PM
LJRXKR's Avatar
Default 5.0 XKR - how close to 300kmh?
This is a question for all those that either know or have done it before - will a stock power XKR be capable of 300kmh if the limiter is removed? If not, how much extra power is necessary?
Reason for asking is in NZ we have an annual LandSpeed Trial event in Reporoa where it is officially timed and your speed measured. Many cars of this generation have hit close to this speed so figured I'd ask to see what's needed. I'm planning on joining this next year. I have correctly speed rated tyres and will upgrade pads/rotors to handle the power needed.
Old Mar 28, 2026 | 09:19 AM
Cee Jay's Avatar
I've had mine up past 177 mph / 285 kph and it was still climbing slowly, but there was a reason I had to discontinue at that point. The elevation in that area is pretty high, so I'm sure the lack of oxygen didn't help performance. Oh, and that was with an XKR/S tune. The 15% power loss due to altitude would more than cover that difference though. I do think I could have gotten pretty close to the 300 kph limit in another minute or so.
Old Mar 28, 2026 | 01:21 PM
LJRXKR's Avatar
Thanks. Any concern with the front end lifting around those speeds? I'm in the early process of making an XKRS-GT style louvered bonnet which should help with heat and also reduce lift a bit.
Old Mar 28, 2026 | 01:42 PM
Cee Jay's Avatar
Not that was apparent, but my undertray (belly pan) is intact. I think maybe some people who state the concern may not have that tray.
Old Mar 31, 2026 | 05:53 AM
neilr's Avatar
The Speed pack aero kit apparently improves high-speed stability significantly and would be a "cheap" upgrade is you don't have it already. Had mine up to 274 kph on the GPS and it was "no sweat" at least from the stability point of view! Was still pulling quite well but the bonnet wasn't down properly on one side so had to give in at that point!!! They say even the base 5.0 has enough power for 300 kph plus but not really the stability to do it safely - they are too softly sprung, more for decent everyday use.
Old Mar 31, 2026 | 09:44 AM
Cee Jay's Avatar
A front splitter helps more than you'd think for front end stability. It cuts off air that wants to get under the front, thereby keeping it more stable.
Old Mar 31, 2026 | 09:53 AM
wymjym's Avatar
A front splitter helps more than you'd think for front end stability. It cuts off air that wants to get under the front, thereby keeping it lower.
as does the hood openings preventing excessive pressure to build and slightly lift the front end
wj
Old Mar 31, 2026 | 07:36 PM
LJRXKR's Avatar
I've got the speed pack spoiler now and will probably get the mina gallery replica of the front lips are it's significantly cheaper. Also toying with the idea of an upper pulley and tune. I'm sure 560+ Hp would be more than enough to get the job done.
Old Mar 31, 2026 | 08:56 PM
Cee Jay's Avatar
Funny (not) thing for me; I got the XKR-S tune and the speed limiter reset specifically to do the Silver State Classic again when NOT categorized with the Hondas and crap like that once more at 130-155 mph (demoralizing). Then before it happened, COVID 19 hit and I didn't go again regardless.
Old Apr 1, 2026 | 02:20 AM
LJRXKR's Avatar
Sorry to hear it. In NZ there aren't very many good straight roads to even attempt this sort of speed and even then doing it in public would be incredibly stupid. So really hoping that I can cross off everything before next March! Will hopefully get a good GoPro setup as well.
ZeroX
May 22, 2021 02:15 PM
dodgerjames
Feb 2, 2014 05:55 AM
Mike V
Dec 21, 2013 08:35 PM
Black Panther
Dec 30, 2010 06:25 AM
05xkrconv
May 6, 2009 08:32 PM
