ABS light- computer says speed sensor but I replaced it and still have issue!
Old Jul 24, 2020 | 01:49 PM
Rob Benjamin's Avatar
Default ABS light- computer says speed sensor but I replaced it and still have issue!
Hello, I have a 2000 XKR and the ABS / Traction control warning lights are on. I had the codes read and the computer says it is the passenger side speed sensor. I have replaced the sensor and the light is still on. I found a thread here about the cables so I measured the ohms and on the cables going under the hood by the wheel well to the sensor it measures at .1 . The wires and underside of the car are in very good shape. This car has never seen snow. I wasn't sure if i measured the cables right so I measured the drivers side one and the ohms read the same so now I am wondering what the next step is, I'm assuming I did it right?. I don't want to get too deep in taking apart the ABS module if it can be avoided. Has anyone had this problem and have any suggestions for the next steps? Thanks from Florida! -Rob
Old Jul 24, 2020 | 01:55 PM
JagV8's Avatar
What actual code?
That will let people (or you) look up Jaguar's full list of possible causes.
The ABS module really counts pulses, so ohms is a very rough check. Bad ohms = faulty. good ohms = may still be faulty. Not to mention it may be OK but the pulse train is bad. Etc.
Old Jul 24, 2020 | 02:59 PM
peterv8's Avatar
You'll get better and more answers if you post in the x100 forum, this is the x150 forum!:-)
Rob Benjamin
Aug 26, 2021 06:46 PM
Striker27
Jul 6, 2015 05:58 PM
stojakovic
Mar 17, 2013 12:39 PM
Bug Splat
Feb 25, 2013 12:26 PM
flyrr100
Sep 28, 2012 04:51 PM
