AC started blowing hot while at idle
Old Nov 14, 2018 | 06:49 AM
chazaroo's Avatar
Default AC started blowing hot while at idle
Happened the other day. I was stuck in traffic and all of a sudden the AC was putting out hot air. Once I started moving again, it worked fine. Now, whenever I start the car, I get hot air until I start driving. Compressor?
Old Nov 14, 2018 | 07:17 AM
jagtoes's Avatar
The 1st thing I would check is to put a set of gauges on the system and check it's pressures. If OK then you need to go back into the the control system which I believe needs to be diagnosed with the dealer link.
10 Limited
Jul 5, 2018 07:15 AM
ysivakumar2
May 24, 2018 09:55 AM
PEM24
Jul 31, 2013 07:56 AM
RidenXj8
May 21, 2013 01:52 PM
Bacardi 151
24
May 29, 2012 05:03 PM
