bocatrip
close
- Join DateMay 2013
- LocationFlorida
Liked:697 Times in 493 Posts
Hi All, My question is simply this. Without taking anything apart..... Can access to observing the condition of the water pump weep hole on a 5.0 naturally aspirated engine be accomplished from the top of the engine or best from the bottom. I'm planning on going down to my Independent shop to look at my water pump before taking it to Jaguar next week. I'm sure he'll be using mirrors to look at it. Thanks all.
jagtoes
close
- Join DateSep 2013
- LocationNY
Liked:1,847 Times in 1,238 Posts
Quote:
I did it using one of those inspection camera's with the flexible fiber-optic . Originally Posted by bocatrip
Hi All, My question is simply this. Without taking anything apart..... Can access to observing the condition of the water pump weep hole on a 5.0 naturally aspirated engine be accomplished from the top of the engine or best from the bottom. I'm planning of going down to my Independent shop to look at my water pump before taking it to Jaguar next week. I'm sure he'll be using mirrors to look at it. Thanks all.
bocatrip
close
- Join DateMay 2013
- LocationFlorida
Quote:
Yes, I've thought of that, but my Indy is old school. Originally Posted by jagtoes
bocatrip
close
- Join DateMay 2013
- LocationFlorida
Quote:
works like a charm.
Took to Indy. There was not enough room to see the weep hole with mirrors. We did see what looked like a coolant stain drip mark on the housing or a tensioner. Could have been and older stain. Can’t tell with certainty on part it was on. I do believe the pump is new as it looks newer as well as the surrounding screws for the air intake etc look as if they’ve been torqued. I’ll relay the info to Jaguar on the day I brung it in.Originally Posted by tarokyama
Just take your smart phone record video and stick it down there,works like a charm.
jahummer
close
- Join DateDec 2008
- LocationFlorida
Liked:2,582 Times in 1,621 Posts
Did the tiny plastic tube that fits on the front of the pump get replaced with the pump? It’s a separate part and cost BUT usually leaks if not replaced with the pump...ask me how I know...
bocatrip
close
- Join DateMay 2013
- LocationFlorida
Quote:
Probably not Jhammer. You have an 08 which should be a different pump setup anyway. There were two part numbers of replaced parts. The pump, AJ813909 and AJ811539 (seal)... That's it.Originally Posted by jahummer
jahummer
close
- Join DateDec 2008
- LocationFlorida
There’s 2 more parts that needed to be replaced, the oil cooler tube that fits on the back of the pump and the little plastic tube that fits on the front of the pump. Very common for these parts to have slow leaks and the oil cooler tube is buried so you can’t see it leak. When I had a new pump fitted last year the cooler tube was replaced but apparently the dealer didn’t do it correctly and it leaked and had to be redone a few months later.
jahummer
close
- Join DateDec 2008
- LocationFlorida
C2Z18658 and C2Z28467
bocatrip
close
- Join DateMay 2013
- LocationFlorida
Quote:
J Hammer. Yours is a 4.2 and supercharged. I’m fairly certain that’s a different set up for your water pump than for the 5.0 naturally aspirated. Originally Posted by jahummer
There’s 2 more parts that need to be replaced, the oil cooler tube that fits on the back of the pump and the little plastic tube that fits on the front of the pump. Very common for these parts to have slow leaks and the oil cooler tube is buried so you can’t see it leak. When I had a bee pump fitted last year the cooler tube was replaced but apparently the dealer didn’t do it correctly and it leaked and had to be redone a few months later.
jahummer
close
- Join DateDec 2008
- LocationFlorida
I wasn’t referring to the 4.2, I was referring to the 5litre. Check the part numbers I posted up, you needed them when the pump was replaced.
bocatrip
close
- Join DateMay 2013
- LocationFlorida
Quote:
Thanks....I'm sure they WERE NOT replaced. I'll mention it when I bring the car in to make sure they are looked at when the system is pressurized. The only advantage I might have is that the car only has 13,000 miles on it.........if that helps or not. Originally Posted by jahummer
Currently Active Users (1)
