Adaptive dynamics falut after coilover installation
Old Dec 26, 2024 | 06:45 PM
TAEUCK Goo's Avatar
Default Adaptive dynamics falut after coilover installation
Hi guys.
As said last time, I yesterday installed BC coilovers for my XKR-S,2013
and as expected, error code showed up.
and the sign is showing all the time, don't know how to turn if off to disappear from the small screen.
Does anybody know which fuse is related to this so that I could check if this error code could be removed with fuse taken out?
Old Dec 30, 2024 | 12:20 AM
TAEUCK Goo's Avatar
Help me....
Old Dec 30, 2024 | 09:03 AM
Cee Jay's Avatar
The way to clear the warning in the center of the cluster is to press the small red triangle on the main TSD on the bottom of the screen slightly to the right side. Then clear the pop-up that appears.
I'm clueless about clearing the fault as my adaptive dynamics works.
Old Dec 31, 2024 | 05:36 AM
guy's Avatar
guy
Put the original dynamic shock absorbers back on?!
Old Dec 31, 2024 | 02:27 PM
ericmcn's Avatar
Why install cheap tat BC coilovers on a XKR-S? You do know they have specific Bilstein shocks just like my 2009 XKR-S has with adaptive control?
Old Jan 1, 2025 | 07:53 PM
TAEUCK Goo's Avatar
Thank you, it works! only leave small yellow triangle on the right side of the screen.
Old Jan 1, 2025 | 07:54 PM
TAEUCK Goo's Avatar
Yes, Yellow Blistein,
I know, oem would be better, but to get the stance. Lowering spring with bilstein oem damper works so bad and the bc coilover is a better alternative I thought.
Old Jan 1, 2025 | 08:03 PM
ericmcn's Avatar
You thought wrong, get that rubbish off the car and put on the stock suspension dampers they are specifically made for the XKR-S
TAEUCK Goo
Jan 6, 2025 01:56 PM
jobitmichal101
Aug 13, 2024 01:14 AM
Fermanaghman
Oct 30, 2012 08:34 AM
bniland
Nov 29, 2010 07:12 PM
