Adjustable coilovers installed, finally!
Old Mar 29, 2019 | 04:58 PM
steve_k_xk's Avatar
A further reduction in weight could come from the front seats 60lbs a piece or simply lose the passenger seat on track day
Attached Thumbnails Adjustable coilovers installed, finally!-img_20190330_195557.jpg
Old Mar 30, 2019 | 08:50 AM
jahummer's Avatar
I've considered replacing with 15 pound race seats, losing the passenger seat only would unbalance the car unless it is properly corner weighted. I've also tried driving with rear seat out and boot trim removed and the road/tire and exhaust noise inside the cabin was overwhelming.
Old Mar 30, 2019 | 02:55 PM
steve_k_xk's Avatar
Thats right you have the muffler delete .
It's amazing how much of the sound is simply muffled when ever I have my over night bag in the boot
Ive been thinking of a weight reduction in my xk so I'm obviously very interested in alot of the mods you have done .
15lb seats that's a hefty saving which brand are they .
Old May 6, 2019 | 05:37 PM
badicedog's Avatar
Originally Posted by jahummer
Actually I did not make much mention of the end result. There are numerous spring rates offered to chose from as well as Swift options. I went middle of the road, the Jag spec is irrelevant because these are completely different dampers. I also have compression and rebound adjustments which take the comfort level from super soft to no travel at all. For my purposes though I may go to a higher rate.
There is no comparison in the ride quality these provide. The car is completely planted with no body roll, squat or dive. Keep in mind I've replaced the majority of the bushes with hard polyurethane and the car is still quiet and smooth. Steering response is crisp and sharp as is acceleration and braking force is much quicker at managing weight transfer. There is no harshness or vibration and the car just glides over the road.
Where did you source the polyurethane bushings? I'm very interested
Old May 6, 2019 | 07:40 PM
jahummer's Avatar
Powerflex, they have track (black) or comfort (purple) versions, I went with the hardest they offered. No regrets, only praise...
https://www.powerflex.co.uk/
Old May 6, 2019 | 09:04 PM
badicedog's Avatar
Is there a specific part # to ask/reference when ordering the coil-overs? Im very interested in these
Old May 6, 2019 | 11:17 PM
jahummer's Avatar
ZX-01 DS series. Their North American facility is located in Orlando FL or you can order them from a dealer. Mine was a one off set but they can make more as they intend to offer them standard.
Old May 6, 2019 | 11:46 PM
  #28
badicedog's Avatar
how difficult is it to adjust the dampening?
Old May 7, 2019 | 01:40 AM
steve_k_xk's Avatar
Is there a dragstrip close by I would love to see how much quicker your 4.2 is now
Old May 7, 2019 | 02:36 PM
  #30
jahummer's Avatar
There is a 30 click compression/rebound adjustment on top of each coilover so it is super easy.
Old May 2, 2020 | 03:53 PM
  #31
Panthro's Avatar
Hey jahummer, now that you've had a while to fully experiment with these shocks, how about a review?
Old May 3, 2020 | 11:10 PM
  #32
badicedog's Avatar
How low does the car sit now? can you upload some pics? thank you as I'm very interested. How about ride quality?
Old May 3, 2020 | 11:13 PM
  #33
badicedog's Avatar
Talking
Originally Posted by tractioninc
What tire sizes are you running these days? I'm curious to know if my car would have a batter balance of traction with a more square setup than the 245(f) 275(r) stock sizes it's fitted with currently.
I'm running 295's up front with 10 x 20 and 315 out back with 11.5 x 20
Old May 4, 2020 | 09:18 AM
  #34
TraxtarXKR's Avatar
And what offset? Pictures?
Old May 4, 2020 | 01:20 PM
  #35
badicedog's Avatar
I actually don’t know the offsets, my tire wheel guy set it up. I’ll see if I can find out.
Old May 6, 2020 | 02:21 AM
  #36
AlexJag's Avatar
Sponsor
Like the front blacked out
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old May 6, 2020 | 10:53 PM
  #37
jahummer's Avatar
Certainly will do that soon. I recently had it corner balanced, after a year the springs had settled about half and inch. I’ll post updated pics as well.
Old May 6, 2020 | 11:16 PM
  #38
jahummer's Avatar
I think they were Sparco but they did not include the base so that adds a couple of pounds. Still have not had time to pull one of the seats and weigh it yet. I need to do that and check CCF in SDD to see what adjustments can me made to the SRS system, if any.
Old May 26, 2020 | 06:10 PM
  #39
jahummer's Avatar
Finally got the car today And I must say now that the coilovers are dialed-in via corner balancing, the transformation is huge. I'm not going to say they are anywhere near being the same car, but I swear it handles like my friends 720S. Camber is still nice and negative by over 1 degree and just a slight bit of toe. Car also has bushes switched to poly. I have to say from a performance perspective, these coilovers are an immense improvement providing a planted, firm, predicable drive experience. I can't say I'd recommend them for daily driving, though there is plenty of adjust-ability for comfort and ride height as desired. Here are some pics. For track, balancing and aero there is a bit of rake from front to back.
Old May 26, 2020 | 06:19 PM
  #40
kj07xk's Avatar
Haven’t seen pictures of your car in awhile, quite a transformation!
