Advice Please - aluminium spacer on a steel space saver
Old Jul 3, 2021 | 01:53 AM
SteveX150's Avatar
Default Advice Please - aluminium spacer on a steel space saver
Does anyone have any information on this,as on another forum a member posted that his supplier of spacers stated that the aluminium spacers should not be used on steel wheels.
Here's the content of the post and my reply
S collins said:I have H&H centric spacers fitted to mine that have a warning not to use with steel wheels (space savers )
I can't find H&H Centric Spacers, did you mean H&R possibly.
Are your spacers permanently fitted to the hubs ?
This is where I'm going to be getting my 7mm spacer from https://motorsport-tech.com/wheel_spacers.html
As it's specifically made for the job I'm not sure what the issue would be for temporary use with a steel space saver wheel. If there is something I've missed I can get the 7mm spacer made from steel rather than aluminium. Any advice greatly received before I push the button on the order.
Old Jul 3, 2021 | 04:25 AM
The warning has some validity if you are going to be fitting spacers permanently.
Your ALUMINIUM standard road wheel is normally bolted to the STEEL hub and the mating faces should be smeared with Aluslip to prevent seizing. I wouldn't worry about the possibility of aluminium/steel interaction between hub/spacer/wheel in the short period of time you are likely to be using a steel spacesaver wheel.
What I would be worried about is where to put the full size wheel once the spacesaver is fitted.
Old Jul 3, 2021 | 04:31 AM
SteveX150's Avatar
Thanks Graham
That's what I'm thinking as well. Here a pic the poster on the other forum uploaded. I think it looks like a steel spacer that he's fitted permanently
I don't have any Aluslip but I do have copperslip, would that do instead ??
What do you think ?
Old Jul 3, 2021 | 04:49 AM
I only mentioned Aluslip which I use because I have a thing about seeing Copaslip marks on aluminium wheels. Either are equally effective.
Bonz
Feb 9, 2026 11:52 AM
myshao
Jul 4, 2023 01:25 PM
xrix4096
Aug 24, 2019 05:02 PM
powerhouse
Jan 1, 2018 04:23 PM
unders
Aug 30, 2013 04:10 PM
