Alcon brakes
Old Aug 23, 2019 | 03:16 AM
D1FWS's Avatar
Default Alcon brakes
Can anyone share detailed information on the Alcon brakes fitted to a 2009 XKR?
Im trying to get maintenance parts from Alcon, but I need part size detail. Piston sizes for example.
The Jaguar part numbers mean nothing to Alcon
Old Aug 26, 2019 | 10:43 AM
Panthro's Avatar
Put "Portfolio Alcon brakes" into the search box. Should bring up a whole bunch of threads with all the information you desire
Old Aug 27, 2019 | 06:33 PM
jahummer's Avatar
They are “tweaked” mono 6 and mono 4 calipers. A google search should yield what you seek or I can lost later. There’s a company Illinois that sells parts and rebuilds. Alcon Kits I think it is called.
Old Aug 28, 2019 | 09:47 AM
D1FWS's Avatar
Still struggling to find the info I need, it would really help to know what width the Alcron rotors are, 28 or 32mm?
Old Aug 28, 2019 | 11:19 AM
jahummer's Avatar
The front rotors are 400mm X 36mm and the rears are 350mm X 28mm
Old Aug 28, 2019 | 11:28 AM
jahummer's Avatar
The rear pistons are 31.8mm and part number PSS3230X550 - pressure seal is part number SES3200X900 and the wiper seal part number is SNW3432X603 - you'll need 4 of each of everything for the rear
The front pistons are 30, 35 & 38mm and part numbers PSS3033X550, PSS3533X550 and PSS3833X550 - pressure seals are SES3000X900, SES3500X900 and SES3800X900 - wiper seals SNW3430X603, SNW3435X634 and SNW4474X621 - you'll need 2 of everything for the front.
Old Sep 1, 2019 | 06:16 AM
‘Oleguy's Avatar
https://alconkits.com/
Talk to Chris the owner. He’ll text, email, phone call with you. He hooked me up with everything I needed. I did my 4 calipers on my ‘08 Portfolio back in Jan.
Old Sep 3, 2019 | 07:27 AM
gkubrak's Avatar
How much $ did that run you for parts only?
Old Sep 3, 2019 | 08:03 AM
‘Oleguy's Avatar
If you go to the website you can see which kits and which pistons you’ll need and the cost.
My calipers where completely rebuilt by his shop with everything new as I had a lot of frozen pistons as the previous owner was ignorant of the importance of fluid changeout. I replaced everything. Rotors, Porterfield RS-4 street/track carbon/kevlar pads which have a ‘softer’ pedal feel but are cleaner on the wheels and rebuilt calibers. Be aware if you have him rebuild them he does not repaint calipers. The paint color is called Ruby Red. I actually found the build print for the Alcon calipers that gave the paint number number, I think in the forum here. Found a place in Tx that sells it. I’ll post the paint number if I can find it again.
RLA3003 Ruby Red.
Old Sep 6, 2019 | 08:53 AM
D1FWS's Avatar
Are you 100% sure the Alcon disks are 36mm and 28mm?
Alcon don’t list parts that fit 36mm disks. They do however mention 32mm disks.
im gathering a lot of info and will soon be in a position to share.
thank you
Old Sep 6, 2019 | 09:36 AM
jahummer's Avatar
thank you
Yes they are and also the same rotor specs as used on the Jeep TrackHawk interestingly enough...before the Jeep, I don't think anything else on the road used a 400mmX36mm rotor.
Old Sep 10, 2019 | 07:44 AM
Panthro's Avatar
The Nissan GTR had an Alcon Super Kit BBK that had 400x36mm rotors, but other than that I think the Portfolio & the Jeep were the only ones that came stock that way.
Old Sep 10, 2019 | 03:25 PM
‘Oleguy's Avatar
thank you
Here is the ALCON UK rep. Remember the time zones
Alex Trevellyan | Account Manager
+44 (0)1827 723709
+44 (0)7341 736965
Gerry Henden
General Tech Help
Aug 21, 2019 11:51 PM
Steve W
Jun 13, 2017 08:23 AM
Chromey35
Jun 5, 2012 01:40 AM
Mar 30, 2007 12:12 PM
