Alcon replacement rotors
Old Oct 21, 2014 | 05:23 AM
olkarz1's Avatar
Default Alcon replacement rotors
Anyone have any luck purchasing aftermarket rotors for the Alcon equipped XKRs?
EBC, Akebono and Hawk confirmed that they don't make any.
Ksport makes a 400mm rotor but will only guarantee them with the purchase of their brake kits and they don't make a brake kit for Jaguar cars.
Old Oct 21, 2014 | 07:31 AM
dd823's Avatar
I had my front ones replaced by my front Alcon rotors and pads Jaguar by my Jag dealer I didn't need them but did it any way $,1,700.00. Was taking a few long trips.
Old Oct 21, 2014 | 09:17 AM
richzak's Avatar
Sounds like you may have a 2008-2009 XKR Portfolio Edition Jaguar.
Have you tried Alcon USA?
Alcon brakes & clutches
Hopefully this helps.
The 350mm and 400mm rotors on the Portfolio Edition is the largest braking system that Jaguar put into their models.
Old Oct 28, 2014 | 12:40 AM
olkarz1's Avatar
Yes richzak that is the exact model that I have. My mechanic says that he can purchase the rotors at a lower cost than the Jaguar dealership but I'm looking for something a little more sports oriented. I like the Ksport design...but they're trying to give up the specs to their rotors!!
Old Oct 30, 2014 | 05:46 AM
olkarz1's Avatar
I've been speaking with Ksport and they make a rotor kit that is the same size as our Alcon units.
Let me know if you are interested and I'll see how we can have these as a via brake option. These are 2 piece rotor designs with a 12 month warranty.
Here's a link to their Super Comp Kits
Ksport SuperComp Big Brake Kit
We would need like 15 paid orders to get a set made. We only build the complete kits with brake caliper and rotor assemblies, so no stock parts of the car would be able to be used.
Eric
Account Manager
Ksport USA - Performance Coilovers, Air Suspension and Brake Systems
Eric@ksportusa.com
Phone: 480-829-8100
Fax: 480-829-8103
Old Oct 30, 2014 | 07:51 AM
Stuart S's Avatar
olkarz1,
Did you see the Ksport prices? Their big brake kits cost more than twice as much as the OEM Jaguar Alcon rotors. Why buy Ksport? How are they "more sports oriented" than the OEM Alcons with 6-piston front and 4-piston rear red calipers by Brembo with the embossed "R" logo? And the crescent shaped slots in the rotors are unique.
I'm very pleased with my Alcons (except for the brake dust, but cleaning the wheels is a small price to pay) and will use only OEM brake parts in this instance. Aftermarket brake parts sometimes are better choices than OEM, but not in this case.
I have 36K miles on my XKR. Front pads replaced at 30K miles without turning rotors, rears still untouched. No noise, shimmy, pulling - simply perfect.
Stuart
Old Oct 30, 2014 | 04:11 PM
dd823's Avatar
Stuart S I Agree with agree with you 100% I replaced my original pads at 40,000 and they still had more millage on them I had OEM installed again and as you said "No noise, shimmy, pulling - simply perfect"
Old Oct 30, 2014 | 04:54 PM
richzak's Avatar
Also agree 120% with Stuart S. Have the Alcon's on my 2009 and the OEM brakes pads on the car and rotors remain with minimal wear. Of course my 2009 only has 16,400 miles. I see no reason to make a change and no reason to go with anything other than the original Alcon rotors and OEM pads when needed.
Of course any braking system is subject to wear and tear depending how hard you run your car. With us older folks, we don't drive as hard as we once did when younger, so the brake systems seem to last allot longer.
Just think what you have to look forward too in the future.
Old Oct 30, 2014 | 06:27 PM
GritsNCornbread's Avatar
I have zero issues with the stock rotors on my Alcon setup. However, I would love to find a brake pad option that provided equal quality without all the brake dust. Still, small price to pay for this fantastic setup we have.
Old Oct 30, 2014 | 07:01 PM
Stuart S's Avatar
If you find a low-dust brake pad, let us know.
THE GOOD, THE BAD, AND THE UGLY:
The Good: I suspect that one reason our Alcon rotors last so long is that the pads have a relatively soft compound that doesn't tend to score the rotors. The Bad: Being a soft compound means that the pads produce more dust that a harder compound. The Ugly: Just look at your wheels!
I'm concerned that low-dust pads (ceramic) might score the Alcon rotors, which are very expensive to replace. I'd rather clean the wheels than have to replace the rotors.
Old Oct 30, 2014 | 07:20 PM
That's an excellent point. I already clean my wheels as part of my usual wash routine, so maybe it's best to not try to fix what isn't broken...
Old Oct 30, 2014 | 07:33 PM
Cambo's Avatar
There are aftermarket discs available in the UK for the Alcon-equipped XKR's but they do not have the half-moon grooves machined in them, the discs are just plain.
They are available from our sponsor SNG Barratt SNG Barratt - The Ultimate Jaguar Parts Specialist
For example, front discs are £400 UK list price each, the aftermarket discs are £45 each...
Old Oct 31, 2014 | 09:20 AM
SNG Barratt USA's Avatar
Former Sponsor
We have a couple of aftermarket options on these here in the US, one with the half moon cut outs and one without. Feel free to call me to discuss.
Regards
William@SngBarratt.Com
Old Oct 31, 2014 | 06:30 PM
olkarz1's Avatar
Good information guys. The upfront costs are greater but the replacement rotors are less that the stock Alcon units.
I'm not having the luck that most are you are experiencing with your brakes. 50K miles on mine and the front rotors are cracked and the rear rotors needs to be replaced too...
So that's $380 for the front pads, $340 for the rear pads, $850 x 2 for the front rotors and $450 x 2 for the rear rotors plus installation.
So that's $3790 at dealer cost plus labor. Those are the prices that were quoted by Hennessey Jaguar
I'm already at the price for the 15.7 (400mm) Ksport SuperComp kit and it comes with a 8 piston brake calipers, instead of our 6, and there are slotted or drilled options for the rotors.
Old Oct 31, 2014 | 07:18 PM
Cambo's Avatar
If you guys want to go a bit hardcore with the Alcon setup then Spires in the UK have 2-piece floating rotors as a "step up"
Braking : XK 5.0 XKR Disc (LH or RH) - Floating (each)
Old Nov 1, 2014 | 08:00 AM
That's where I saw those! I knew I had run across a rather nice looking set of slotted rotors a while back, but I have so many sites bookmarked now that I just never bothered to actively figure out which one had the rotors on it.
I imagine though that even if these offer a performance increase over what we already enjoy, these won't be doing anything to help the dust issue. Still, I'd buy 'em for appearance purposes alone.
Old Nov 1, 2014 | 04:59 PM
Cambo's Avatar
If you want to reduce dust then you need to change the pads.
I have EBC Yellowstuff pads on my XJR with slotted rotors, virtually NO dust whatsoever, and the braking is phenominal.
Also just fitted EBC Redstuff pads on my Land Rover, still getting through the bed-in period, but even in the 1st 3 weeks i've seen a massive reduction in dust. I also had the Red's on my old X-Type & once i'd put a few thousand kms on them the dust output was down to similar levels as what I see on the XJR now.
There are lots of other "low-dust" pads out there. If you are still running OEM pads then that will be the biggest source of brake dust...
Old Nov 1, 2014 | 05:44 PM
olkarz1's Avatar
Cambo351 I have the same Yellow Stuff pads on the rear and the Alcons on the front and I must say...the braking power with the combo is ridiculous!!! I am very happy with the new stopping performance.
Too bad the previous owner was soooo hard on the brakes with this car, that it needs both front and rear rotors on pads at just 47K miles!! But once I get the brakes swapped out I'll enjoy it more that I am right now.
Old Jan 30, 2017 | 11:15 PM
Stuart S's Avatar
Updating this thread: See https://www.jaguarforums.com/forum/x...-cheap-171582/
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
