Ancillary Belt Fitting on XKR
Old Mar 3, 2026 | 01:18 AM
Colt23's Avatar
Default Ancillary Belt Fitting on XKR
Hi,
having removal the failed alternator and looking to fit the new alternator and ancillary belt. Whilst I've plenty of post for fitting the main belt connected to the supercharger and co I have found little on fitting this belt and specific the movement of the tensioner. It appears you need a special tool or at least a breaker bar with a square head of the end, and to fit in the square opening on the tensioner. (I have managed to release the nut on the tensioner) Can anybody kindly offer some advice on the tool and if I am on the right track with releasing the pressure from this tensioner.
Many thanks.
Colt (New Zealand)
XKR 2007
Old Mar 3, 2026 | 01:57 AM
ChiefyO's Avatar
1/2 square drive breaker bar into the square hole and lever on that
Old Mar 3, 2026 | 04:06 AM
RichardS's Avatar
From memory, I think it's 3/8 inch square drive found on any 3/8th socket set.
Richard
Old Mar 4, 2026 | 03:47 AM
Jaguar!2's Avatar
When I was looking to do this job myself I found online a tool thin but sturdy:
Amazon Amazon
Really good as access is tight, did not use on my Jag as ended up getting in a good mobile mechanic in the end and had him do the water pump at the same time, if yours has not been changed recommend you use the opportunity to change yours. I did use this on the Audi due to length and thinness allows easy use
Old Mar 5, 2026 | 06:13 PM
bgpenguin21's Avatar
I just replaced both of the belts on my XKR within the last few months and I used this...
8PCS Serpentine Belt Tool Kit 8PCS Serpentine Belt Tool Kit
Will it last long enough for my grandson to inherit it from me? Probably not. Did it do the job? Yes, and very well.
Old Mar 6, 2026 | 09:18 AM
clubairth1's Avatar
Community Influencer
I also use and recommend the same type of tool Jaguar!2 linked above. The flat bar makes access easier and the long handles give you enough leverage so you can easily hold the tensioner all the way open. Many variations of the tool including a Harbor Freight version.
Worthwhile tool to own.
MattArnold
May 1, 2020 02:32 PM
Jose Arellano
Dec 16, 2017 05:20 PM
dhferry1
Nov 30, 2013 12:25 PM
cpm53
Jan 21, 2011 07:35 PM
lrizzell
Jul 6, 2008 12:55 PM
