Another coolant leak plugged ... whats next?!
Old Mar 19, 2021 | 10:05 AM
gkubrak's Avatar
Default Another coolant leak plugged ... whats next?!
As i'm sure others are aware, coolant leaks on this car seem to just migrate from 1 spot to the next.
First it was some bad clamping causing hoses to tear near the S/C, then a worn o-ring on the ECT sensor, and now the latest.... worn o-ring inside the plastic housing of this hose:
A few options with this one:
- RTV and silicone wrap (this was terrible and didn't work)
- Replace the whole hose PN C2P2142 for about $80 (on back order from the motherland and didn't want to wait, also to lazy to get to the bottom clamp for the whole hose)
- Replace just the failed O-ring inside the plastic (tried this too, but could not get the right size)
- Chop of the plastic part and replace with a 1.25" to 1" silicone reducer + 1" barbed coupler + some clamps
Last option is what you're seeing here. Eliminates the o-ring/plastic failure mode altogether.
Currently taking bets on what will leak next!!
Valley hoses have already been replace preventatively. My money is on the 2 connectors by the axillary pump that go into the heater circuit. They are plastic and probably have O-rings inside them as well.
Old Mar 19, 2021 | 10:12 AM
Cee Jay's Avatar
Jaguar is Ford, and I just had to replace a seal much like your top picture on my old F-150. It took about a minute and a half to do with a factory O-ring and a screwdriver to pry the fitting unlocked. No leaks so far.
Old Mar 19, 2021 | 10:17 AM
Rummy636's Avatar
Hope theres a lip on the metal side or that thing has a chance of slowly slipping off under pressure.
Old Mar 19, 2021 | 10:30 AM
gkubrak's Avatar
Yea it would have been real easy that way, but I'm not sure where to find that exact O-ring size.
You don't think the barbed fitting is good enough? The bottom part worries me a bit but I think it should hold.
Old Mar 21, 2021 | 09:00 PM
gkubrak's Avatar
Drove 425 miles this weekend and for the first time in a few months .... coolant level didn't go down!! Let's hope it stays that way.
Old Mar 21, 2021 | 11:30 PM
AlexJag's Avatar
Sponsor
A question? What is your expension cap rated at ?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Mar 23, 2021 | 09:33 AM
gkubrak's Avatar
Its OEM so 200kPA (~30psi).
trkyam
Aug 8, 2025 04:14 PM
ricardoa1
May 3, 2020 02:51 PM
smgdata
Sep 5, 2019 06:23 PM
vdpnyc
Dec 4, 2016 09:48 AM
Clasico
Apr 2, 2015 08:09 AM
