Anyone with electric fan?
Old Feb 5, 2021 | 09:49 PM
kazi's Avatar
Default Anyone with electric fan?
Didn't find much here on electric fan conversion. Anyone had any sucess with a puller setup? I know they are more efficient than pushers, but I will have room for a pusher by swapping it out with the heat exchanger when I do the killer chiller. KC and bigger ic pump is for sure but would love some feedback on fans because if I dont do it now, I probably never will.
Old Feb 6, 2021 | 12:47 AM
MarkyUK's Avatar
Kazi
Are you talking about something like this?
https://www.ebay.co.uk/itm/Revotec-E...oAAOSw~LpcXrE-
Sorry am not familiar with the benefits of fitting such a thing, would you care to enlighten me?
Old Feb 6, 2021 | 03:01 AM
kazi's Avatar
Yes a kit like that. Fortunately there are much less expensive options out there. Advantages are a thermostat and/or switch allows you to turn fan on and off at desired temps, lighter than mechanical setup, saves space, looks cooler, less water pump bearing stress, and more hp/tq. Hp gain is from the crank not having to work as hard. Its been dyno proven at around a 5 hp gain.
Old Feb 6, 2021 | 05:32 AM
barnsie's Avatar
Do you think a 5 bhp gain would be significant or noticeable? I can see that it wouldn't be the primary reason for installing an electric fan, but TBH I can't see it being much of a positive benefit either.
Old Feb 6, 2021 | 07:23 AM
jahummer's Avatar
Odd, my 2008 XKR has an electric fan.
Old Feb 8, 2021 | 10:02 AM
MarkyUK's Avatar
Barnsie agreed, I'd not feel 5bhp increase on a 510 V8, so to my way of thinking hardly worthwhile spending the money, surely you'd get more from higher octane fuel?
Old Feb 8, 2021 | 11:36 AM
gkubrak's Avatar
Previous owner must have done conversion ....
Old Feb 8, 2021 | 05:48 PM
AlexJag's Avatar
Sponsor
Yes mine too! we apear to be converted
I heard there might be advantages to run with no fan at all..
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
eksjaysix
XJ40 ( XJ81 )
Aug 28, 2020 10:40 PM
Roger95
XJ40 ( XJ81 )
Jun 27, 2018 09:20 AM
Rhett
Oct 23, 2015 03:25 AM
