Backlash in drivetrain
Old Jul 12, 2019 | 08:31 PM
Reverend Sam's Avatar
Default Backlash in drivetrain
Now that I've fixed all of the problems that were causing fault codes and turning on warning lights, I've started to pay attention to the less obvious stuff. My biggest worry right now is that there seems to be a lot of backlash in the drivetrain. If I'm driving in traffic and I take my foot off the gas to slow down, then step on the gas to speed up, there's a noticeable jolt when the power from the engine hits the wheels. It's not a normal jolt, it feels like there's some play in the drivetrain. Hopefully it's not a transmission issue.
My first thought is that it might be engine mounts, but I honestly have no idea. What are the symptoms of faulty engine mounts? And what else might be causing a jerk/thud when going from braking to accelerating?
Old Jul 12, 2019 | 08:39 PM
Kongo1's Avatar
Does it what happened when coming to a slow rolling stop?
Old Jul 12, 2019 | 08:47 PM
tberg's Avatar
I have had my engine mounts broken and replaced in the past but I have a high mileage car. But it's not inconceivable that a car with as much power and torque as the XKR 5.0L has would tear through motor and/or transmission mounts. It's a good place to start looking.
Old Jul 12, 2019 | 09:29 PM
No, it only happens when I go from slowing down to stepping on the gas. It can happen at any speed, but I don't recall noticing it when coming to a stop.
Old Jul 18, 2019 | 02:22 PM
guy's Avatar
guy
I play in the drivetrain would be an exceptional situation... but you did change the e-diff..
Perhaps you're feeling a 'clunk' in the transmission?? Though a fluid change helps, a ZF repair depot can really smooth out the jolts and harsh shifts..
Old Jul 19, 2019 | 08:28 AM
110reef's Avatar
Open the hood. Put car in drive with foot on brake. Hit the gas a little. If the engine moves, then you may have a broken motor mount.
matl
Feb 7, 2012 08:09 AM
Adam Lueb
Nov 10, 2010 03:24 PM
worldrider
May 4, 2010 08:11 AM
jagxtype
Feb 28, 2009 11:16 AM
adreasx
Dec 25, 2008 08:16 AM
