backup wire location and color
Old Apr 29, 2017 | 04:32 PM
RedRider48's Avatar
Default backup wire location and color
Hey Guys,
I have a need to locate my backup light lead for tapping for signal power.
Anyone know the location in the boot?
Thanks for any "leads"...yes, I know it's a Pun, Ha, Ha, Ha....
Old Apr 29, 2017 | 05:22 PM
kj07xk's Avatar
See post #66 in this thread:
https://www.jaguarforums.com/forum/x...d-55139/page4/
George Kale posted his instructions for upgrading to LED taillights in the 2007-2009 cars, and he identifies the leads in there.
Old Apr 29, 2017 | 05:46 PM
RedRider48's Avatar
Thanks I'll look into it....
Old Apr 29, 2017 | 06:27 PM
Sean W's Avatar
Easiest access is at the Auxiliary Junction Box. Plug CA023.
See page 2 here and type in CA023 and you'll see where it is.
Old Apr 29, 2017 | 10:17 PM
kj07xk's Avatar
Guess it depends on where you need access to the signal, in the cabin (via the junction box), or in the trunk (via the wiring loom).
Old Apr 29, 2017 | 10:27 PM
RedRider48's Avatar
Thanks for your reply. I found this link as well and it covers my same years.
https://www.jaguarforums.com/forum/x...camera-131998/
BTW all, It's one of the cleanest rear view camera projects, I've seen on the subject of adding real rear view camera.
Old Apr 29, 2017 | 10:33 PM
RedRider48's Avatar
Thanks, I like this location better. Yeah, and gotta luv the intense diagram too!
Old Apr 30, 2017 | 11:09 AM
Sean W's Avatar
No it doesn't actually. You access where it is the easiest to access since the loom is sourced from the junction box. The wire, regardless of connection can be easily hidden back into boot and fished through in under 5 minutes. Trying to access the loom at the tail light is a royal pain, at least on my back.
I recall you mentioning the need to add a relay due to pulsing interference at the bulb. Splicing the wire at the junction box eliminated the need for a relay as there was no pulse in the signal. Clear as a bell.
Old Apr 30, 2017 | 11:10 AM
Sean W's Avatar
Frankly, I'm impressed that they have that diagram. It makes things much easier to find after reading the wiring diagram. Glad it helps.
Old Apr 30, 2017 | 05:00 PM
kj07xk's Avatar
To install the LED tail lights, I had to open up wiring looms anyway, so it was the most convenient location for that task.
If you're splicing the same wire I did, the pulsing (or not) should be the same at either end of the wire.
As per George Kale's installation instructions, I found the relays necessary, as the backup lights would flash and then go out without them.
Perhaps what you connected to the line was not as sensitive to the pulsing as the LED lamp units?
Old Apr 30, 2017 | 06:22 PM
Sean W's Avatar
My bad, I forgot you were converting to LED in your project. I was honing in on the reverse camera only.
Old Apr 30, 2017 | 09:05 PM
kj07xk's Avatar
No harm, no foul.
Old Apr 30, 2017 | 10:12 PM
RedRider48's Avatar
Yeah Sean, i'm focused on a reverse camera idea too! That's my reason for the post.
Old Aug 18, 2021 | 02:43 PM
GetITcoy60's Avatar
Default tail light socket inop
I have an 07 jaguar xk, my right tail light socket is not work, is it ok to splice,and replace just the one socket?
Old Aug 18, 2021 | 03:12 PM
RedRider48's Avatar
If all efforts to clean your existing socket, then, you have no other choice. I see no reason you cannot R&R that particular bulb socket with an approved replacement.
Old Aug 18, 2021 | 03:24 PM
GetITcoy60's Avatar
THANKS, Red any specific cleaners
Old Aug 18, 2021 | 03:26 PM
Cee Jay's Avatar
Sand Paper? Maybe first some CRC Contact Cleaner, but do NOT get any on plastic, it eats it.
Old Aug 18, 2021 | 03:36 PM
GetITcoy60's Avatar
Thanks again, Sir will do
Old Aug 18, 2021 | 03:45 PM
RedRider48's Avatar
Also, there is a product specifically for electronic components. One that I know is "Tuner" cleaner. This is when a Dremel with small wire brushes comes in handy.
A Dremel style tool and attachments should be in every DIY'fers tool caddy.
Old Aug 18, 2021 | 04:46 PM
Craniac's Avatar
Just finished adding a back up camera. Used the wire off CA023 for signal. Installed camera on bottom of rear lip. Very easy to run wire through boot. There is a rubber grommet about four inches into the spare tire well on the right side. Wire then runs under the vertical carpet piece on right side. Up and over gas tank. There is already a hole near the top of the structure for gas tank. Comes out right above the rear fuse panel. Wires then run under rear seat and tucked up under the trim on side of center console.
