Bad Catalytic Convertor
Old Dec 11, 2015 | 09:28 AM
LstFord's Avatar
Default Bad Catalytic Convertor
So the saga continues. The federal warranty ran out three weeks before I took it in. JAG USA was no help with the bad oil change, didn't tighten oil filter, that left oil down my street, well they did say they would now pick up the car and clean the car. Not to mention they did the oil change after the Detail and left grease all over the drivers seat. Just a bad day. THE QUISTION is should I spend $1,800 for a new Catalytic convertor or put on new pipes. When you put on a new exhaust system does it include the Catalytic convertors? How much for the new system and which one?
Attached Thumbnails Bad Catalytic Convertor-img_20151104_163118730.jpg   Bad Catalytic Convertor-img_20151204_121331469.jpg
Old Dec 11, 2015 | 09:31 PM
flyc2c's Avatar
Exhausts are almost always "cat back" and do not include converters. If you use an aftermarket high flow converter you're looking at a re-tune of the ECU. Your cheapest route is an OEM converter. Mine went bad before the warranty. Was it the drivers side?
Old Dec 12, 2015 | 06:56 AM
steve_k_xk's Avatar
Might as well get 100 cell cats installed whilst your at it , it will free up some power and improve sound
I had left and right 100cell cats installed on my xk for $850aud
Old Dec 12, 2015 | 08:48 AM
LstFord's Avatar
I am thinking about doing just that, New pipes, cats, pully and tune. I would need to find the right place to get it done. I am in SE Michigan. I left a message at Mina.
Thanks for help
Old Dec 12, 2015 | 02:31 PM
steve_k_xk's Avatar
Thanks for help
Sounds like your xk is definitely heading in the right direction when it comes to power upgrades . Make sure they do a pre dyno run prior to the engine modifications
Good luck with it and be sure to keep us all posted with your progress
perfectson
Apr 3, 2019 02:42 PM
philwarner
33
Dec 13, 2015 07:29 AM
yellowapple
Nov 29, 2015 04:29 AM
talashek
Nov 26, 2015 12:18 AM
pab
XF (X260)
Nov 14, 2015 04:09 PM
