Bad Evening in Mobile - Coolant Leak
Old Oct 30, 2022 | 07:11 PM
MudDog's Avatar
Default Bad Evening in Mobile - Coolant Leak
Oh well, Let the grandson use the Jag for about 2 weeks now. Good Kid.
Today I get the call, Car is overheating. of course I think its Hallowene and Im being pranked. No such luck.
Car is parked is a big parking lot, I get there with a Gallon of Coolant. Pour it in and it runs out the bottom as fast as I pour it. No previous indications of any leaking.
Im watching for location and dont see anything from above. Looking underneath its coming out about the middle of the engine , but then the covers are all in place.
I'll bring it home in the morning.
Any thoughts what Im in for ?
Old Oct 30, 2022 | 07:58 PM
guy's Avatar
guy
split bottom hose??
Old Oct 30, 2022 | 10:20 PM
MudDog's Avatar
Lets say it is
Recommend a place to buy one , please
Old Oct 31, 2022 | 05:01 AM
guy's Avatar
guy
my answer is Jaguar. It has lasted this long...
In fact as it has probably not been done... it's certainly time for all the hoses.
Old Oct 31, 2022 | 05:04 PM
Arminius's Avatar
I also would change ALL the water pipes at once.
I paid € 800 for all water pipes, Original Jaguar, including thermostat and thermostat housing, but from an independent vendor. Haven´t had them installed up to now. If it ain´t broke, don´t fix it!
You should think about changing some other things, too: Water pump? Timing chain?
Hermann
Old Oct 31, 2022 | 06:24 PM
Sean W's Avatar
Hermann
Na. Water pump issues apply to the 5.0 liter as do the timing chain tensioners. No need to go down the rabbit hole on the 07. Mud Dog if you do start changing hoses and decide to do the thermostat, replace the whole housing. Plastic.... They don't make metal ones either. Sorry no help with sourcing the hoses other than guy's suggestion. I can help with a parts search once you ID the hose.
Old Oct 31, 2022 | 08:15 PM
Gator8's Avatar
You do have a dealer in Mobile (good folks) but of course that means dealer prices. If you have time to wait on parts, I’ve been pleased with Rimmer Bros.
Old Nov 1, 2022 | 08:42 AM
MudDog's Avatar
Putting the car up on the lift today . Will report findings.
Old Nov 1, 2022 | 08:31 PM
Ranchero50's Avatar
It's an XK with the plastic T-stat housing. Pop it apart and make sure that it's not turning gray and shredding inside from the excessive heat. BTDT with the kids old '05 NA LS...
Old Nov 4, 2022 | 12:31 PM
MudDog's Avatar
Here it is
Old Nov 4, 2022 | 01:00 PM
MudDog's Avatar
Wow this SUX
Engine Oil Cooler Split.
Whats as bad is the replacement at Jaguar Palm Beach dosent look anything like this.
Engine Oil Cooler
Part Number: AJ810959
Old Nov 4, 2022 | 01:37 PM
kj07xk's Avatar
Originally Posted by MudDog
Wow this SUX
Engine Oil Cooler
If you’re looking at line drawings, they’re usually wrong, don’t look like the part at all.
Just make sure you get the right type, the XK and XKR coolers are different. (Bought an XKR version by mistake, and it didn’t look anything like my XK version, returned it and got the XK version).
Old Nov 4, 2022 | 04:37 PM
MudDog's Avatar
The rest of the story
looking dead on at the cooler from the front , its obvious one corner is lower down than the other.
That corner took a hit as can be seen.
The cooler split. Now what., Couple things come to mind. New is about $500 , Used if I could find one , Tig this one.
The Grandson had to have hit something , probably a speedbump.
Old Nov 4, 2022 | 05:16 PM
Cee Jay's Avatar
I think that although your grandson is a 'good kid', he couldn't resist playing with way more car than he was ready for. Heck, most adults would get into trouble driving these things.
Old Nov 4, 2022 | 05:26 PM
karamayoko's Avatar
Agreed with CeeJay as a 24 year old I can never resist to punch the peddle just too hear that sweet sound! also live in the U.S home of potholes and junk on the streets so you can only imagine how many potholes I dodge in a day but ive seen the wifey hit them plenty of times
Old Nov 4, 2022 | 07:36 PM
Ranchero50's Avatar
Google the Jaguar P/N and see what comes up. Today I received the 55k mile driveshaft from Pacific via eBay, $66 w tax delivered from Michigan. Looks very good in spite of being a little dirty. Unobtainable from the dealer.
Old Nov 4, 2022 | 09:05 PM
kj07xk's Avatar
Think I paid ~$135 for a used one from Pacific on eBay a few years ago (my eBay history doesn’t go back far enough).
Might try contacting breakers directly to see if they have one.
Interim? Bend it back and weld that seam?
Old Nov 4, 2022 | 10:47 PM
MudDog's Avatar
Googled the number an something unusual came up
Got me curious because it Looks exactly like mine.
Engine Oil Cooler Fits 2016-2018 Ford E-350 Super Duty 6.8L V10 GAS SOHC Very Interesting $75
Old Nov 5, 2022 | 12:28 AM
kj07xk's Avatar
Huh? A few years later, and Ford still had some in the parts bin?
Old Nov 5, 2022 | 08:05 AM
jahummer's Avatar
Good find, we should start a sticky with a list of modern Ford parts which suit Jags....
