battery going dead
Old Aug 8, 2019 | 04:14 PM
clubking's Avatar
Default battery going dead
2007 xk convertible with a newish battery that tests good will only last 5 days before going dead...put a meter on the battery and shows no draw is this common where do I look to fix this
Old Aug 8, 2019 | 04:23 PM
NBCat's Avatar
Even though a battery may be new, that doesn't necessarily mean it's fully charged. Prior to condemning the battery for replacement, check the voltage across the terminals with a voltmeter. The battery should show a minimum of 12.6 volts, if not, charge it for 8 to 10 hours at 3 to 5 amps and then retest it.
Old Aug 8, 2019 | 05:12 PM
Cee Jay's Avatar
I leave my batteries on the charger at least overnight, and since 99% of chargers made in the past 15 years are "smart" and turn themselves off when the charge is full, it isn't a bad thing to just Let 'er Rip until finished, no matter how long.
You could also take the battery to nearly any parts store and they will check the load ability for you. Sometimes even charge it for zero dollars.
Old Aug 8, 2019 | 08:28 PM
Stuart S's Avatar
If you don't drive your XK daily and mainly take short drives around town to run errands, your battery probably isn't getting adequately charged. Many Forum members use a battery maintainer on a regular basis, with CTEK being the most popular and recommended brand.
See this thread for details: https://www.jaguarforums.com/forum/x...s-73471/page2/
Old Aug 9, 2019 | 04:12 AM
JonWat's Avatar
How to find parasitic battery drain
snkpkp
Jan 14, 2021 09:52 AM
Robert Laughton
Feb 13, 2017 09:44 AM
superchargedtr6
Jul 26, 2014 08:16 AM
supraman
Jul 17, 2011 11:14 PM
grasshopper
Dec 2, 2009 09:49 PM
