belts change
Old Nov 15, 2019 | 08:23 AM
George05's Avatar
Default belts change
Hi guys looking for advice please . at what age or millage , Do the ancillary belts on my car need changed out ? my car will be 9 years old in January and is currently on 60k miles . Thanks
Old Nov 15, 2019 | 09:12 AM
Here's the Jaguar recommendation:
Odd that belt changes are only MILEAGE based in this 2010 document. The current equivalent document 2019 document gives:
every 7 YEARS or 105K MILES for the supercharger belt
every 10 YEARS or 150K MILES for the accessory belt
Old Nov 15, 2019 | 11:13 AM
George05's Avatar
Thank you Graham . it was my understanding that a fuel pump belt or an oil pump belt also needed changed also ?
Old Nov 15, 2019 | 11:25 AM
Queen and Country's Avatar
George, on the accessory belt, they dont give way like the belts of before, there is ample warning.
I would replace only if you saw cracks and it was making noise.
I have regretted replacing serpentine belts on other cars unnecessarily as I have never found one as good of quality as oem belt.
Where the original has lasted a decade, I found myself replacing the aftermarket ones every 3 years.
Old Nov 15, 2019 | 11:42 AM
George05's Avatar
Thanks Q&C visual inspection the belts look good . but will change them next year a year early just to be on the safe side
Old Nov 15, 2019 | 12:52 PM
NO - oil pump is driven by an auxilliary chain and the submersible electric fuel pump is mounted directly on the tank.
Old Nov 15, 2019 | 01:14 PM
George05's Avatar
Many thanks again Graham . Great info and advice on here
Old Nov 15, 2019 | 01:15 PM
Cee Jay's Avatar
I thought he referred to the HIGH pressure pumps. Me, I have No Idea how those are driven, other by engine rotation.
Old Nov 15, 2019 | 03:02 PM
George you've probably charged people to change their wiper arm belt- metaphorically speaking, and now the rooters are coming home.
High pressure pumps are driven by timing chain.
Old Nov 15, 2019 | 03:49 PM
George05's Avatar
True
Mike198
Jun 16, 2017 12:51 PM
cyber3d
General Tech Help
Jun 23, 2015 08:29 AM
David_h
May 11, 2014 09:29 PM
stephen11962
Apr 4, 2013 05:40 PM
