Blower Motor Brand Recommendations
Old Dec 13, 2025 | 02:01 PM
Quasimo1's Avatar
Default Blower Motor Brand Recommendations
Hi Everyone. The blower motor in my 2007 XK has developed a squeak and is rusty. A quick search shows the OEM motor is no longer available. Is there a recommended aftermarket replacement? I see replacement motors from brands, API, GPD, 4 Seasons, UAC, VDO, and ACM, but am not familiar with any of those brands. Is there a consensus for the best replacement brand?
Old Dec 13, 2025 | 02:09 PM
guy's Avatar
guy
the oem solution lasted you from '07 - '25...
Old Dec 13, 2025 | 08:03 PM
sony2000's Avatar
UAC....
Old Dec 14, 2025 | 02:23 AM
Woo5ie's Avatar
It’s the same blower motor as the F Type. I fitted a used one off a F type from EBay and got the adapter power harness from Jag
There are plenty of used ones for the F type on EBay and in good nick as the F Type doesn’t have the duckbill issue
The harness was around a £1.
The PN is on a previous post on here.
Old Dec 14, 2025 | 07:36 AM
guy's Avatar
guy
Partially... there was a wiring change between the current available fan and the original included with your '07.
The solution from Jag includes the adapter.
Old Dec 15, 2025 | 11:25 AM
stockcar's Avatar
If it is rusty the chances are the a/c drain (duckbill) is blocked and backing up and dripping through the motor. A common problem but a pig to fix, I know from experience! I believe the early f-type motor is the same. It looks identical.
Old Dec 15, 2025 | 01:54 PM
McJag222's Avatar
Mine developed a squeak which was caused by carbon dust/bits from the brushes collecting in the bottom - cleaned it out (after dismantling) and it has been fine ever since.
Old Dec 15, 2025 | 04:57 PM
guy's Avatar
guy
been there, done that... three times. I'm hopeful the new motor can wait for the attention another 10 years.
Old Dec 16, 2025 | 12:26 PM
synrgy's Avatar
The duckbill problem caused this twice in my 2008 XK 'vert. I replaced it with whatever brand they sell at Auto Zone with no issues. Note that the problem often ruins the motor controller as well. I got the controller at Auto Zone as well. It is located right next to the motor, so the installation was a simple procedure. It was still working well after about 5or 6 years when I sold the car.
mghirsch
Sep 1, 2022 08:54 AM
Kewpie
Sep 25, 2016 03:37 PM
chiefshb
Sep 30, 2012 10:37 AM
pan84
Sep 16, 2011 12:50 PM
Jan 20, 2011 04:14 AM
