Brake Lamp failure light infrequently
Old Mar 23, 2025 | 09:27 AM
07xk's Avatar
Default Brake Lamp failure light infrequently
Good Morning XK folks,
My brake lamp failure light comes on randomly. Not sure but it seems only when the weather is a bit cooler. All lights work and when I turn off the engine and then restart it goes out. Sometimes does not come on at all. Any thoughts from the fantastic brain trust would be greatly appreciated. 2007 model NA 4.2.
Old Mar 23, 2025 | 09:46 AM
Kongo1's Avatar
My 08 XK NA did this recently before the light staying on. Bulb was indeed burned out. Easy fix, IIRC bulb #7528 available at parts store. 3 minute video on YouTube made the job easy.
Old Mar 23, 2025 | 10:02 AM
07xk's Avatar
Thanks for the quick reply, all the bulbs are working at the moment. Maybe a tiny bit of corrosion on one of them is the reason it seems to be random. I might just think about replacing the two outboard bulbs and also switch to LED bulbs if these are still the original type.
Steve
Old Mar 23, 2025 | 12:45 PM
Cee Jay's Avatar
Originally Posted by 07xk
........................ I might just think about replacing the two outboard bulbs and also switch to LED bulbs if these are still the original type.
Steve
LED bulbs with ballast, or you'll get permanent MILs.
Old Mar 24, 2025 | 05:22 AM
Jaunty's Avatar
In my experience, if bulbs are replaced with good generic bulbs, the Jaguar bulb check system will sometimes think they are not working. The only cure in my experience is to dig deep in your pocket and replace with genuine Jaguar bulbs from a dealer or SNG Barratt. I have written this up fully on here a year or so ago, but God knows where it is now..
Old Mar 24, 2025 | 10:33 AM
07xk's Avatar
Thanks much for the info, I will look into bulbs from an OEM source and see if they have a brand that is different from generic brands available everywhere.
S
98Jagxjr
Jan 16, 2025 07:25 AM
Martez78
Dec 10, 2023 08:24 AM
capitol1
Mar 19, 2022 10:15 PM
platinummaker
Jan 20, 2014 08:14 PM
bmw745ion19s
Aug 14, 2008 09:56 PM
