C0034 front right wheel sensor
Old Mar 16, 2025 | 05:33 PM
ksattic's Avatar
Unhappy C0034 front right wheel sensor
The other day I was driving when the car started pulsing the brakes (felt like ABS) even though I was driving normally in the dry. Shortly after that, a number of warning lights came on: ABS, E-Diff, Stability, DSC. I pulled the codes and it is showing C0034, front right wheel sensor. I replaced the sensor and used a camera to inspect the condition of the reluctor ring, cleaning it with brake cleaner and a narrow nylon brush. Cleared codes but the same happens immediately again. Swapped sensors L-R and same happens, same code.
I do not have access to a Jaguar mechanic/dealership. The two near me caused damage to both my vehicles (the other is a 2019 I-PACE... sigh). My assumption is now a faulty ABS module, wiring, or bad reluctor ring (even though it looks OK). Any suggestions before I try to find someone?
I'm in Colorado, USA.
Old Mar 17, 2025 | 03:51 AM
RichardS's Avatar
The first thing to do is to make absolutely sure that your battery is fully charged with a resting voltage above 12.6V and fully up to spec as these errors can be classic battery-related issues.
Richard
Old Mar 18, 2025 | 11:33 AM
ksattic's Avatar
Thanks for the response. I fitted a new battery last month but it was a good idea for me to check the voltage prior to starting the engine and reproducing the problem. I cleared the codes, measured 12.86V, then started the engine and drove down the road. The codes were thrown again. I noticed that a sub-code is also being thrown, C0033, right front tone wheel. I cleaned the tone wheel with a nylon brush but the problem still happens. I've taken it to an independent shop for further diagnosis and I've also asked them to check the battery and alternator. I will update this thread shortly.
Old Mar 20, 2025 | 12:58 AM
xalty's Avatar
you can’t clean the tone wheel…it’s internal to the bolt on wheel bearing
replace the bearing
Old Mar 24, 2025 | 10:44 AM
ksattic's Avatar
The battery checked out OK, and the wheel bearing with tone ring was replaced. All OK now. Thanks for the advice!
Dell Gailey
Mar 25, 2024 04:47 PM
max224
Jul 23, 2020 10:30 AM
Racer X
Aug 3, 2015 11:35 AM
dijmand
28
May 19, 2014 12:44 PM
yardpro
Jan 28, 2013 03:22 PM
