Brake pad dust
Old Nov 11, 2013 | 11:57 PM
Fastlane'scat's Avatar
Default Brake pad dust
Tired of cleaning pad/rotor dust, Chevy sure has figured out how to stop making it. Ford has a real bad problem, So when it comes time to change out the OEM pads what pads have you gone to that doesn't make all this dust?
Old Nov 12, 2013 | 12:13 AM
Versatile's Avatar
Interesting question
I'd like to know that as well
Old Nov 12, 2013 | 06:33 AM
user 2029223's Avatar
Banned
This is an old question. You can install ceramic pads. This will cure the problem and if you are not an aggressive driver the extra wear on your disks will be negligible. This approach has worked for me on several Jags. I also use a "wheel protectant" product put out by Eagle 1. There are others.
FWIW - Autozone/Discount auto carries a good ceramic pad for the XKs but not the XJRs. You need not pay thru the nose for "so called" premium/race quality pads being sold at exorbitant prices. You will notice a slight unobjectional difference in brake feel.
Old Nov 12, 2013 | 07:46 AM
jagtoes's Avatar
This had been a typical problem with my kids Audi A4. It is normal on most metallic pads. I look at my Lexus and from wash to wash you can hardly see the dust. The secret is ceramic pads which a lot of manufactures have gone to. I switched out the Audi pads as well as the ones on our Volvo and the problem goes away. There is no apparent difference in brake performance nor is there a wear issue with the rotors. Unless you track your car on a regular basis you should not feel any difference except for the lack of visible dust. They also seem to not be as corrosive to the wheels. Just my observations.
Old Nov 12, 2013 | 10:13 AM
Brake dust is a regular topic on every model tech forum here.
Although it's almost as contentious a subject as 'best oil' debates, the favourite or most often recommended brake pad usually emerges as Akebono Ceramic.
There was a recent thread in XK/XKR recently about Akebono:
https://www.jaguarforums.com/forum/x...-brakes-80179/
Although production of front pads (EUR1241) was apparently delayed, Tire Rack are listing both them and rear pads ((EUR1314)
http://www.tirerack.com/brakes/brake...toModClar=Base
I'm 3000 miles away so I'll leave it to US members to confirm these are actually available from stock.
Old Nov 12, 2013 | 11:38 AM
jagtoes's Avatar
That's what we used on the Audi and they worked great.
Old Nov 12, 2013 | 02:41 PM
mosesbotbol's Avatar
I used on my VDP and was quite happy. Will be replacing to these pads when I have to change the fronts. I replaced the rears with OEM about 3 months ago, but disks were near end-of-life, so change all disks when I do the front.
Old Nov 12, 2013 | 03:35 PM
tbird6's Avatar
Another vote for the Akebono's.
I have them on my 2005 STR for the last 50K+ miles and won't use anything else. They should have been factory fitted!!
Old Nov 12, 2013 | 07:33 PM
TFlan's Avatar
Replaced front and rears with EBC rotors and EBC "Red Stuff" ceramic pads 7000 miles ago. Am very pleased with the change...brake dust is down about 90% from what was on before.
I also had the calipers and rotor hats painted gloss black and the red color of the pads shows through. Kinda', sorta' matches the red growler center badges.
I had read the discussions about the Akebono line but they weren't available for the four wheels at the time.
Best regards,
Old Nov 12, 2013 | 08:36 PM
cpf's Avatar
cpf
Did the Akebono Ceramic all around on my 2009 XK. Best money ever spent. NO BRAKE DUST!!!!! I have nothing to do on my weekends now.
Old Nov 12, 2013 | 10:22 PM
Thanks you all, you would think the mfg would put these on from the get go. How about the rotors, how many turns before you get to min wall thinkness? talking about normal driving no track time.
Old Nov 12, 2013 | 10:26 PM
CleverName's Avatar
The reality behind Ceramic is that they still dust just as much as other pads, but the dust is light tan in color so it is less visible.
For a good cleaning product I recommend Sonax Full Effect (I think they just renamed it to Sonax Extreme?) to keep the manual labor to a minimum.
Just installed Yellow stuff last weekend! waiting to bed them in for a decent eval (and for the record I don't care how badly a pad dusts, as long as it does what I ask of it with precision)!
Old Nov 12, 2013 | 10:35 PM
Skeeter's Avatar
Many threads on this topic (not intended as the frequent aggressive 'check before asking' response, just a suggestion to look around and you'll find some golden info in previous threads (some of which are VERY long).
I tried almost everything from Armor All wheel protectant to other anti-binding sprays and cremes, only to find that NONE of them worked for the factory pads. Being as I own a 2011, I get free brake jobs from Jag, so I'm stuck with factory pads.
I decided to take the plunge and plasti-dip my rims. On a black car with red calipers, I've had nothing but immensely positive reviews, and most importantly I think it makes the car look that much better AND completely eliminates the brake dust issue. It just doesn't show on black rims.
Otherwise the consensus was ceramic or the like, with some disadvantages (squeaking when not warmed up), to just dealing with the dust.
Best of luck,
Skeeter
Old Nov 13, 2013 | 02:00 PM
Thanks to all who have replied. I looked at Tire Rack this morning and they only show break pads for the front no mention of the rear. After reading thru responses I see some have mention a part number for the rear being EUR 1095 and EUR1314, is there a difference in the two?
Now if you had to change the rotors because of Min wall thickness would you go with OEM rotors or aftermarket and if so which one?
H20boy
Dec 24, 2024 03:23 PM
perezal
Dec 29, 2015 08:48 PM
ahunt4
Sep 19, 2015 09:49 AM
1964Daimler
Sep 9, 2015 11:28 AM
JagLove86
Sep 6, 2015 10:36 PM
