Brake pad wear sensor intermittent issue
Old May 4, 2018 | 09:54 PM
trkyam's Avatar
Default Brake pad wear sensor intermittent issue
After changing my front brake pads and changing the brake pad
wear sensor, I get the alert "brake pads low" but ONLY
after waiting in traffic holding down the brake pedal for 4-5 minutes,
other than that the alert never comes up.
Any idea whats going on here?
Old May 5, 2018 | 06:43 AM
jagtoes's Avatar
Considering this happened after the sensor replacement there would either be a problem with the sensor or with the installation of it. Some how it must be grounding out so I would recheck the way it is mounted and the wire for a potential short. Also look at the connector.
Old May 7, 2018 | 09:44 AM
Feffman's Avatar
Over the weekend, I changed my pads after a sustained pad wear warning (it was occasional after car washes). Did the fronts thinking they were the likely culprit. Light stayed on, turns out it was the rears. My point, check the rear pads/sensor on passenger side.
New brake pads and sensors all around for about $200 and a bit of cussing at the rear caliper re-set.
Feff
Old May 7, 2018 | 10:13 AM
britannia's Avatar
Feffman,
You are correct! on XK's rear pads wear out first because Jaguar dug into parts bin (S type?) and pads are a wee bit too small............... but still the best Jaguar I have ever owed!!!
Cheers, Adrian
Old May 7, 2018 | 11:18 AM
Cee Jay's Avatar
Originally Posted by britannia
Feffman,
Cheers, Adrian
Freudian Slip much?
Old May 7, 2018 | 10:05 PM
trkyam's Avatar
Is there a way to inspect the inner rear pad without removing the caliper?
The rear outter pad is thick and looks very good.
Old May 12, 2018 | 10:38 AM
britannia's Avatar
Have you tried a flex camera? That's what I use!; cheap from Harbor Freight........
Cheers, Adrian
Old May 13, 2018 | 11:20 AM
djhaydel's Avatar
You can disconnect each sensor one a time sensor and see if the connected one comes into alarm during the same events. The rear sensor is on the passenger side rear on my 2013.
Once you pull the wheel off you should be able see how worn the rears pads/rotors are.
My rear sensor was going in and out of alarm when the pads where worn down and the sensor had worn to the point of making contact. still has about another 3-4mm before being totally worn out.
Replacing the the rear pads where not all that bad but you do have to screw and push the piston back in the caliper for re-assembly. I only screwed mine back far enough to allow for reassembly of the caliper and pads. I was changing the rotors also so that made it easier.
texevora
Oct 31, 2015 08:43 AM
Rique
Aug 5, 2013 09:32 AM
The Coupe
Oct 20, 2011 02:40 PM
biffta
Oct 16, 2011 04:51 PM
Shouldbeworkin
Oct 18, 2010 02:00 PM
