Burning rubber smell and some visible whisps of smoke
Old Jan 30, 2024 | 07:41 PM
jahummer's Avatar
Originally Posted by xalty
yes and new breather diaphragms
they come bolt on ready to install
+1
Old Jan 31, 2024 | 09:11 AM
sony2000's Avatar
If the oil leaks were small and over a long period of time, and the fix is thousands of dollars, then do a Roadkill temporary fix and pressure spray
the lower outsides of the valve covers. Clean them up and see how long it takes to get the smell back. Maybe a detailer can do that. The second Roadkill style fix is find a can of gasket sealer for the oil sump. I am sure someone has that on the market!
Old Jan 31, 2024 | 10:19 AM
SDCR_XK's Avatar
Along the same lines, could a re-torque of the VC studs, correct the leaks?
Old Jan 31, 2024 | 11:04 AM
TraxtarXKR's Avatar
Originally Posted by jahummer
It can all be done in less than an hour. Looks challenging, but it's not as difficult as it may seem. (I've done it before)
Here's a video done at a main dealer on a vehicle with much less accessibility to the engine compartment than the X150.
https://www.youtube.com/watch?v=xpA2DPVQ-L0&t=6s
So are we suggesting a casual mechanic should be able to do a full valve cover job on the 5.0 SC engine in a weekend?
I recently paid to get the rear water jacket replaced, along with some brittle cooling hoses, oil cooler gasket, etc.
Looking into purchasing the valve cover assemblies and attempting to do this myself in the next few months when it's warmer.
I'll likely replace the injectors (Bosch 62120) and plugs (current recommended replacement?), and breather diaphragms (C2D60163 - 2pcs) if those are recommended "while you're at it" jobs
Anything else I should have on hand for this job? Special tools, part numbers, etc?
Can I reuse the gaskets recently replaced (intake, supercharger, etc) or are those 1 time use only and need to buy again?
Old Jan 31, 2024 | 12:24 PM
jahummer's Avatar
Supercharger gasket can be reused (carefully) but intake manifold gaskets are crush type and they’re quite inexpensive so best to replace with new. New valve covers might include the diaphragms?
Old Jan 31, 2024 | 12:29 PM
TraxtarXKR's Avatar
Indeed, looks like you are correct.
Norbertas
Jul 13, 2025 07:29 AM
Cibermac
Nov 15, 2021 02:04 PM
mjmck87
Oct 7, 2015 06:46 PM
Glennbar66
Nov 26, 2012 04:28 AM
ltmtc
Mar 26, 2011 07:56 AM
