A/C drain duck bill fix - my solution
Old Jul 24, 2022 | 11:05 AM
  #341
Stu72's Avatar
I have seen some old familiar names on this chat who were the first to successfully slice open or slice off the damn duckbill. I am one of those who created the cutting tool as described and sliced mine open. Several years later, still no condensate water in the cabin, nor any car exhaust. The car exhaust fear is ridiculous. once sliced or cut off the new opening is still less than a dime in size.The risk you run with finger tickling or lubing the duckbill is that it will work until it does not. Once water successfully sloshes onto the blower motor fan you risk shorting out the fan ($300 + ) and or the fan speed control relay ($300+). It happened to me; and theses things never occur at a convenient time. As mine is not a super charged XK, it was an easier & durable fix. I do value the sincere ingenuity on this forum, and some times the ideas work, sometimes they don’t as you may have read on this subject alone. As for those who’s comments are only to snipe at others, stick to twitter or fakebook.
Old Jul 24, 2022 | 02:23 PM
  #342
KiwiAuldPhart's Avatar
Thank you Stu77, I am forever grateful to you, the thread starter DpezXKS whom got the ball rolling, kj07xk who gave us a tool, great pics, dimensions and instructions on how to locate the duck bill, and Chris77 with the master stroke, the endoscope.....you guys saved me an expensive fix
Old Jul 25, 2022 | 11:03 AM
  #343
Aarcuda's Avatar
I wasnt saying you would get exhaust gases in the car. I was saying you could. And these arent my theories either. These are the reasons the engineers used to decide upon the use of the duckbill. So please stop calling me a genius because these arent my ideas or concepts. They were the design considerations of the jaguar engineers. Boy I never imagined being attacked just for trying to explain the reasons behind a design but I get some folks just like to bully others in order to feel superior. Good luck in all your endeavors
Old Jul 25, 2022 | 11:55 AM
  #344
Sean W's Avatar
@Aarcuda I can't speak for others but I'm not attacking you. My question is valid. Where would you pour the cleaner? How do you access the evaporator drain pan? If you don't have a procedure, I'm fine with "I don't know". Still waiting for a reply as if there is such a way, others would be interested.
Old Jul 25, 2022 | 12:43 PM
  #345
trkyam's Avatar
It has been documented that the purpose of the duckbill is to keep out insects from entering the system.
As with any petrol vehicle, there will be some amount of exhaust gas entering the cabin,
the question is how much and what is the acceptable safe amount. the difference with duckbill and without?
most likely immeasurable. The problem with the duckbill is that the rubber becomes hardened due to age
and due to heat and fails to open when required, most japanese cars use an open duck bill type. (and never get clogged)
Old Jul 25, 2022 | 03:00 PM
  #346
George Abitbol's Avatar
Spewing nonsense and taking people from above sure is not going to bring you flowers.
Now feel free to call yourself bullied when you just reap what you sow...
Old Jul 26, 2022 | 04:04 AM
  #347
RichardS's Avatar
Originally Posted by tarokyama
.... most japanese cars use an open duck bill type. (and never get clogged)
Most cars, full stop.
Richard
Old Jun 8, 2023 | 08:26 PM
  #348
Howell's Avatar
Default Duckbill tube size
I want to buy a right angle tool to fit on flex cable for cutting duck bill, I think duck bill is about 7 inches into the space, what I need to know is size, internal id, of tube duckbill sits in and how far up the tube is the end of the duckblll. My mechanic has reached to put some oil on tip and that worked for a while, now need to cut end off duckbill
i think a small right angle drive with a cutter could do the trick, but need dimensional information
i will post if I can make it work
Old Jun 8, 2023 | 08:36 PM
  #349
steve_k_xk's Avatar
if someone could clear the photo up with engine out it'll be able to pinpoint
Old Jun 8, 2023 | 09:19 PM
  #350
kj07xk's Avatar
I think most of the info you request are in this thread. Read postings like 35, 44, and 322.
How far into ‘the space’ the duckbill duct sits, depends on where you start your measurement, and 7” sounds a bit too much. It’s a cramped space, so getting some right angle drive in there is a bit optimistic. Look at the tools used in those above posts to get an idea of the space you’re dealing with. I had to put my tool in sideways and then twist to angle it up into the hole where duckbill lives. Up and down motion to saw through the duckbill was very small strokes, not much space.
Good luck.
Old Jun 9, 2023 | 10:13 AM
  #351
Stu72's Avatar
I second looking back at the referenced posts for your answer. You will need to fashion your own tool as I and others have done. You will find measurements
for these home made tools in the posts as well. The best tool I saw was a means of fastening an exacto blade to ones finger. That tool appeared only after I had made my own tool from a design provided here and sliced my duckbill to shreds. No more problems for years now. Good Luck, Seek and You will Find.
Old Oct 27, 2023 | 12:28 PM
  #352
Woo5ie's Avatar
I have tried a few times with little success in cutting the duckbill or so it seems.
I seem to get no water dripping from the fan when ticking over in the drive but as soon as I drive off I get quite lot drop down from the fan within a few yards. AC system could not have produced this amount in the short time.
so question is there a reservoir in the unit that maybe full up and overflows in the direction of the fan when setting off.
It also appeared to be more excessive water when I accelerated.
Frustrating and I will need to revisit.
I need some more blades.
Old Oct 28, 2023 | 04:17 AM
  #353
RichardS's Avatar
The reservoir is simply the plastic housing under the evaporator which fills up when the duckbill is blocked. Eventually it fills up enough to overflow into the fan housing. If the duckbill were simply an open pipe, like most other cars, then the condensate would drain out as fast as it develops.
Old Sep 4, 2024 | 04:42 PM
  #354
Martin B's Avatar
Default Duckbill Photos
Attached are photos of my duckbill.
I'm curious what the 'eye' parts on the duckbill might be. I cannot get my hand near the duckbill to feel. Tight fit with the supercharger (XKR).
Thanks,
Martin
Attached Thumbnails A/C drain duck bill fix - my solution-photo_2024-09-04-13_34_22_793.jpg   A/C drain duck bill fix - my solution-photo_2024-09-04-13_34_35_354.jpg   A/C drain duck bill fix - my solution-photo_2024-09-04-13_38_49_899.jpg
Old Sep 4, 2024 | 11:43 PM
  #355
kj07xk's Avatar
Spooky, the duck is watching you.
Old Sep 5, 2024 | 03:02 AM
  #356
RichardS's Avatar
Thanks,
Martin
By the "eye parts" are you referring to the drops of condensate water which are about to drip off the bottom of the duckbill? If so, this is the point of the duckbill. It gives the condensate a short pipe to run along and then pass through the semi-closed duckbill lips before dripping off down through the hole in the metal plate and then running over the bellhousing and onto the ground.
Richard
Old Sep 5, 2024 | 08:13 AM
  #357
guy's Avatar
guy
And all these years later, mine still works as it should, like a charm.
Old Sep 5, 2024 | 08:16 AM
  #358
kj07xk's Avatar
You probably feed your duck regularly.
Old Sep 5, 2024 | 08:40 AM
  #359
RichardS's Avatar
Mine's been chopped!
Richard
Old Sep 5, 2024 | 01:32 PM
  #360
guy's Avatar
guy
I prefer roasted or BBQ
