Can anyone confirm what this is?
Old Oct 12, 2016 | 08:48 AM
jahummer's Avatar
Default Can anyone confirm what this is?
Can anyone confirm what this is? I am referring to the thin vacuum line with what appears to be a plug on the end of it.
Old Oct 12, 2016 | 11:53 AM
Cee Jay's Avatar
That's a check-valve slash diagnostic cap. All it does is close off the end of the vacuum line, but for many purposes. They are usually like mini waste gates, but also a handy vacuum test spot. Yours has the permanent plug on the end, the little flattened part that goes into the disk.
Old Oct 12, 2016 | 12:01 PM
kj07xk's Avatar
That's also the point where 'flyc2c' tapped into for his pressure sensor to feed into his HKS Camp2, to get boost reading on his infotainment screen.
See post #31 in this thread:
https://www.jaguarforums.com/forum/x...-138621/page2/
The line apparently starts at a manifold port, and then splits to go to the fuel pressure regulator and this test port.
paulyling
Nov 3, 2016 09:07 PM
Tcasmarcus
Oct 12, 2016 02:29 PM
97 Xk8 mayhem
Oct 8, 2016 01:27 AM
rsims
Oct 6, 2016 09:33 PM
4litre
Sep 27, 2016 07:54 AM
