Can someone identify and confirm if these wheels will fit 5.0 XKR?
Old Dec 31, 2017 | 11:10 AM
Simon Tan's Avatar
Default Can someone identify and confirm if these wheels will fit 5.0 XKR?
Local seller has a set of these rims on Facebook marketplace for $100. They look like 18" Velas to me but he insists they are 20" taken from a 2014 XF. They do also look like 20" Turbines that I've found online but can't tell for sure. This guy is about an hour away, so I was wondering if there's a way to confirm what they are. Don't rims usually have some sort of raised lettering or inscription somewhere that provides dimensions?
Edit: Seller just sent this other pic from the back side, but still nothing to confirm dimensions.
Attached Thumbnails Can someone identify and confirm if these wheels will fit 5.0 XKR?-26236023_143554583030725_1691032929_o.jpg   Can someone identify and confirm if these wheels will fit 5.0 XKR?-26236594_143583779694472_2056619720_o.jpg
Old Dec 31, 2017 | 12:30 PM
Sean W's Avatar
The part number is on the back side of the rime. See if he'll send you that.
Old Dec 31, 2017 | 12:42 PM
Cee Jay's Avatar
Look like Velas, didn't know they made 20 inchers, only 18s like you said.
Old Dec 31, 2017 | 12:58 PM
Ranchero50's Avatar
2012-2013 Jaguar XF 18in 59885 - All Factory Wheels
Curious if they would fit over the stock XKR caliper...
Old Dec 31, 2017 | 02:21 PM
Simon Tan's Avatar
I was hoping for a set of these, which I think would work pretty well:
ALY59915/59922 Jaguar F Type Wheel Silver #T2R1864
At $100 for the set, it's so tempting, but I'm pretty sure they are the 18" Velas.
Old Jan 1, 2018 | 01:46 PM
sparky fuze's Avatar
Why not ask the seller to take some pictures with a tape measure across the diameter of the wheel, and another with the tape measure across the outer width of the wheel? And also across two of the bolt hole dimensions. Then you will have all the sizes you need.
Old Jan 1, 2018 | 03:04 PM
Ranchero50's Avatar
Because that's most likely where the 20" measurement came from. Tires are measured from the inside of the opening, not the lip of the rim.
'80's Metric TRX rims caused all sorts of grief as did 16.5's.
Old Jan 1, 2018 | 03:57 PM
shemp's Avatar
Right. My 19" wheels measure 20.5" outside diamter
Old Jan 2, 2018 | 02:38 PM
Rick'sJag's Avatar
Smile An hour away??
It's just an hour away? The price is right, I would make the trip, to see if they fit, and are not damaged. Take the cash with you, if they are OK, bring those babies home.
croco
Jul 19, 2017 08:59 PM
rfarmery
Jan 24, 2017 08:13 PM
Muti007
Mar 4, 2015 07:14 AM
Amadauss
30
Nov 29, 2011 12:50 PM
quaker13
Jan 10, 2011 09:04 PM
