Can the Torque app show supercharger boost?
Torque app shows it without setting up custom parameters. Although I believe it reads a little lower by around 1 psi lower than actual boost at least on my car .
Nice setup CeeJay !, I want to get around doing that on my car instead of constantly messing with my phone
What's the max that you see at Wot?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
I've not really stared at the gauge during WOT cuz 'driving', but a glance every now and then makes me believe somewhere right around 12 psi. I COULD check Torque for Max Value, but I just never have. I could set up a chronograph on a different page I guess, then go in there every so often and check it out. That's a good thing about Torque, you can have I think seven pages of stuff, and many things per page.
The figured it out ,doesn't say boost just vacuum but changes to boost when you get on it.
Cee Jay (09-27-2019)
Received 1,908 Likes
’Lower cost’ would be the ‘Sean W’ method using an android based box.
Both use a GVIF unit, so that install is the same.
Comes down to sort of ‘plug and play’ with the Camp2, vs ‘some setup required’ with the android.
DGL (09-28-2019)
Installation would be similar.
Camp2’s pop up periodically on ebay, androids you can order today.
Probably comes down to your budget and comfort level with setting up an android box.
DGL (09-28-2019)
Cee Jay (10-02-2019)
They were around $700 new I think. To me Android Auto is worthless unless you can manipulate it through the touch screen. I paid $500 for mine and it was used. Whatever floats your boat.
kj07xk (10-02-2019)
