Is Carbon Buildup on valves a concern? 5.0L SC
Old Nov 13, 2019 | 12:22 PM
KrazyIvanUSA's Avatar
Default Is Carbon Buildup on valves a concern? 5.0L SC
I understand that GDI can have issues with carbon buildup. I also understand that some manufacturers have worked to solve this issue by having dual injectors with one spraying below the valve and one above to keep it clean. I can't seem to find if the 5.0L SC in my 2010 has this tech or not. Does anyone know? Or may it be a good idea to run injector cleaner through every 5-10k miles?
Thanks.
Old Nov 13, 2019 | 12:25 PM
gkubrak's Avatar
Download the repair manual. I would assume the injector operation is detailed in there.
Old Nov 13, 2019 | 12:55 PM
Don-T's Avatar
Thanks.
Jag does not use that tech. I think Acura does so. Injector cleaner isn't a bad idea but it doesn't clean the valves. CRC makes a cleaner specifically for DFI engines but has to be introduced upstream of the intake valves.
Old Nov 13, 2019 | 02:03 PM
badicedog's Avatar
Where do I download the repair manual?
Old Nov 13, 2019 | 02:25 PM
Stuart S's Avatar
Repair Manuals are in one of the "sticky" threads at the top of the first page of this X150 Forum.
Old Nov 13, 2019 | 02:47 PM
Cee Jay's Avatar
Carbon buildup on the back of intake valves is a Very Real concern on GDI engines. Google it, take a peek at all the photos. It's some nasty stuff.
Old Nov 13, 2019 | 04:07 PM
jackra_1's Avatar
At least two other threads on this topic in this Forum.
Old Nov 14, 2019 | 04:03 PM
CleverName's Avatar
Welcome to the forum Krazy! Be sure to update your signature with info on your car so we can all be more helpful!
As Cee Jay and Jackra_1 point out, the 5.0l does indeed experience the buildup problem. The 4.2l does not.
Fuel "additives" do not address the problem, and tend to offer more a placebo effect.
I'm personally on my 3 direct injection car (Audi, Lexus, Jaguar) and also as mentioned, only my Lexus had an extra injector on the intake to fight this problem.
I have used theBG induction cleaning system which was available at my local Ford dealership, with significant gains in output. There are many similar systems out there now that others may recommend that may be equally as good or better. (BG was just one of the first to identify and offer a viable treatment.)
I would now make this a bi-annual maintenance practice IMHO.
Old Nov 14, 2019 | 04:29 PM
Sean W's Avatar
Here's the link to the manual for 2010 onward
http://www.jagrepair.com/images/Auto...XKworkshop.pdf
Old Nov 14, 2019 | 04:34 PM
jackra_1's Avatar
The 5.0 engine does have better oil control than the 4.2 which means you may well not get as much soft carbon build up in the charge coolers on SC cars which
is a real problem on the 4.2 engine with a super charger.
Which is why I have an oil catch can on my XJR 4.2.
As I mentioned in another thread I will try out CRC on my 2013 NA Rover soon.
Old Nov 14, 2019 | 04:57 PM
jackra_1's Avatar
https://www.jaguarforums.com/forum/x...leaner-225304/
The above thread started by Queen and Country is the one I was referring to in the previous post.
Old Nov 14, 2019 | 04:58 PM
drumcarfar's Avatar
Default Oil catch can on Type R
Has anyone installed an oil catch can on an F Type R??
Old Nov 14, 2019 | 05:08 PM
Stuart S's Avatar
You should have deleted your question, since you reposted it on the correct F-Type Forum.
https://www.jaguarforums.com/forum/f-type-x152-72/
A Moderator should delete this and the preceding post.
Old Nov 14, 2019 | 05:16 PM
jackra_1's Avatar
https://www.jaguarforums.com/forum/x...-207259/page3/
The above is a "generic" thread on oil catch cans which may be of interest.
Alan E L
Aug 20, 2019 05:12 PM
Sean W
Dec 1, 2016 09:16 AM
rosanova
Aug 8, 2016 02:24 PM
Blackcoog
Nov 16, 2011 06:56 AM
loaks111
Jul 10, 2008 10:18 AM
